Java Mapscript with Japanese Encoding
Mario Basa
mario.basa at GMAIL.COM
Thu Aug 31 11:14:28 EDT 2006
Umberto,
Nope.
I use Emacs to write my programs and it always tells you what encoding
it uses at the bottom task bar. There is absolutely no way that it can
be in any other format than Shift_JIS. Also, if I don't use the
-encoding parameter whenever I compile, javac will complain since it
won't know how to handle double byte characters. These are so basic
for us who uses kanji characters (and its numerous encodings) every
single day.
Anyway, I'll look at how QueryByAttributeUnicode is compiled.
mario.
On 8/31/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> On 8/31/06, Mario Basa <mario.basa at gmail.com> wrote:
> > Hello Umberto,
> > As always, thanks for the quick reply.
> > Unfortunately, even if I change both LANG and LC_ALL to Shift_JIS,
> > layer.getAttributes still can not get a match. It is only when the
> > shapefile is in UTF-8 and when the tomcat environment is also in UTF-8
> > can a match be found.
> > I have a funny feeling that the query value is always converted to
> > UTF-8 first before doing a search. Just a hunch though.
> My opinion is that the Java source file where you defined the search
> string is not Shift_JIS encoded.
> Checklist:
> 1) check encoding of your Java source file
> 2) convert it to Shif_JIS
> 3) compile it and make sure to pass the -encoding option to javac
> 4) run it and report success
> 5) send me all your money ;-)
> If you look closely at how QueryByAttributeUnicode is compiled you
> will notice that javac receives a special parameter (-encoding) to
> tell it how the source file has been encoded.
> Alternatively you can try to pass the search string as the second
> command line arg to QueryByAttributeUnicode to avoid this encodin
> issue altogether.
> The section International language support in mapscript/java/README
> has useful pointers that should help you in understanding more of what
> is happening under the hood.
> Regards,
> Umberto
> > Thanks.
> > mario.
> > On 8/30/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> > > Mario,
> > > Java mapscript should support international charsets, only make sure
> > > that the environment when you start tomcat (or the servlet container
> > > of your choice) is configured with the wanted locale.
> > > Also note that LANG has lower precedence than the LC_* variables and
> > > in particular check LC_ALL. For example if you set LANG=it_IT and
> > > LC_ALL=en_US then the setting in effect is en_US.
> > > There is an example using the german charset in the examples directory.
> > > HTH,
> > > Umberto
> > > On 8/29/06, Mario Basa <mario.basa at gmail.com> wrote:
> > > > Hello,
> > > > I have been testing the java mapscript of mapserver-4.10-beta1 and it
> > > > seems that layer.queryByAttributes only works with UTF-8 character
> > > > encoded shape files and only if tomcat is started also in UTF-8
> > > > (ja_JP.UTF-8) LANG environment.
> > > > I tried using Shift_JIS encoded shape files (99% of all shape files
> > > > here in Japan are Shift_JIS encoded) and tomcat restarted in UTF-8
> > > > and then Shift_JIS LANG environments, but I couldn't get it to work
> > > > anymore, as in layer.queryByAttributes can not match query items
> > > > anymore with the data.
> > > > Is there a work-around for this.
> > > > Thanks.
> > > > Mario.
