phpmapscript projection problem(?)
Hal Mueller
hal at MOBILEGEOGRAPHICS.COM
Mon Dec 4 18:52:08 EST 2006
Take Mapserver and PHPMapscript out of the loop.
Generate some test cases and pipe them through
the proj standalone executable.
I also don't quite understand why you are using
a=6378137 rf=298.25722101. I would think they
would be 6377397.155 and 299.1528128
respectively. But I haven't looked closely.
How were the towgs84 parameters derived?
Is there a standard set of test points for this
projection? What sort of systematic error are
you seeing?
At 11:52 PM +0200 12/4/06, Andreas T wrote:
>The original projection of the point that I am
>trying to reproject is a greek projection system
>called "TM3". It has the following attributes:
>projection = Tranvserse Mercator 3o
>ellpisoid = bessel
>lon0 = 23ÉÕ42' 58''.815
>lat0 = 34
>towgs84 = DX=456.39, DY=372.62, DZ=496,82,
>DangleX=0, DangleY=0, DangleZ=0.000363,
>ppm=0.0000159
>False E = 200000
>False N = 0
>Ellipse big axis = 6377397.155m
>1/f = 1/299.1528128
>k0 = 0.9999
>units = m
>[CODE]
>$projInObj = ms_newprojectionobj("proj
>=tmerc,ellps=bessel,towgs84=456.39,372.62,496,82,0,0d00m00363s,0.0000159,".
>"lat_0=34d0m0s,lon_0=23d42m58815s,x_0=200000,units=m,k=0.9999,a=6378137,rf=298.25722101");
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061204/611704e1/attachment.html
