mapObj.zoomRectangle from Java Mapscript.
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Thu Dec 7 02:51:21 EST 2006
I build the rect for use with queryByRectangle as follows:
return new rectObj(
(x1<x2) ? x1 : x2,
(y1<y2) ? y1 : y2,
(x1<x2) ? x2 : x1,
(y1<y2) ? y2 : y1,
0
x1,x2,y1,y2 need to be in map coordinates (not pizels).
Umberto
On 12/6/06, José Vilson de Mello de Farias <vilson.farias at digitro.com.br> wrote:
> Greetings people from Mapserver,
> I've been unsuccessfully trying to make mapObj.zoomRectangle work. My
> goal is to write a simple zoom by rectangle, which lets you to select an
> image area from web browser and submit those coordenates for zoom processing
> inside mapserver. Although I've checked my code more than once, the error
> seems to be related to the way mapserver deals with these coordenates. Do
> you know if there is any problem in mapObj.zoomRectangle tool in Java
> Mapscript? How could I zoom to a specific pixel location using
> zoomRectangle?
> Suppose I have a map with the following size and extent :
> SIZE 800 450
> EXTENT -180.000000 -90.000000 180.000000 90
> Here is my Java code :
> mapObj mapa = new mapObj("./world.map");
> rectObj maxExtent = new rectObj(-180, -90, 180, 90, mapscript.MS_FALSE);
> //map full extent
> rectObj actualExtent = new rectObj(-120, -60, 160, 45, mapscript.MS_FALSE);
> //map actual extent
> rectObj pxArea = new rectObj(170, 200, 270, 400, mapscript.MS_FALSE);
> //image coordenates for zooming
> mapa.zoomRectangle(pxArea, mapa.getWidth(), mapa.getHeight(), actualExtent,
> maxExtent);
> When I try to execute the zoomRectangle command, the following exception
> is thrown :
> java.lang.UnknownError: mapscript::mapObj::zoomRectangle():
> General error message. image rectangle miny >= maxy
> edu.umn.gis.mapscript.mapscriptJNI.mapObj_zoomRectangle(Native
> Method)
> edu.umn.gis.mapscript.mapObj.zoomRectangle(mapObj.java:554)
> By the way, what does the last param of rectObj constructor mean? Is
> imageunits a boolean to indicate whether coordenates are image-relative or
> geographical values? If I try to set it to MS_TRUE I get a different
> exception.
> java.lang.UnknownError: rectObj(): Invalid rectangle. image (pixel/line)
> units { 'minx': 248.000000 , 'miny': 194.000000 , 'maxx': 387.000000 ,
> 'maxy': 259.000000 }
> edu.umn.gis.mapscript.mapscriptJNI.new_rectObj(Native
> Method)
> edu.umn.gis.mapscript.rectObj.<init>(rectObj.java:69)
> Could you please help me to solve this situation?
> Best regards,
> Analista de Sistemas
> SSE - Segurança Pública
> DÍGITRO TECNOLOGIA
> E-mail: vilson.farias at digitro.com.br
> Messenger: vilsonfarias at hotmail.com
> Site: www.digitro.com.br
