Antwort: [UMN_MAPSERVER-USERS] Java with MapServer on Projection
Benedikt Rothe
umn-ms at HYDROTEC.DE
Thu Dec 7 08:00:01 EST 2006
Hi
Maybe
http://article.gmane.org/gmane.comp.gis.mapserver.user/18799/
is helpfull.
Benedikt
UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
07.12.2006 12:33:37:
> Dear friends,
> I am trying to use the PROJECTION section in a map file using MapScritpt
> via Java on Windows.
> The map file is very basic, and when using the map file reported below
the
> program works fine; if I uncomment the three lines about PROJECTION I
have
> the following error:
> Exception in thread "main" java.lang.UnknownError: No such file or
directory
> at edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
> at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:312)
> at Demo.Main.<init>(Main.java:10)
> at Demo.Main.main(Main.java:16)
> Java Result: 1
> I "suspect" the reason is some unreacheable file or directory used by
the
> proj.dll (??), however the PATH include C:\ms4w\Apache\cgi-bin (where
> proj.dll is located whith the distribution package).
> The map file is the following (and it works if used via PHP !!):
> MAP
> IMAGETYPE PNG
> EXTENT 126500 3907000 1521500 5302000
> UNITS METERS
> SIZE 600 600
> IMAGECOLOR 230 230 90
> TEMPLATEPATTERN "itasca"
> LAYER
> NAME "areas"
> CONNECTIONTYPE postgis
> CONNECTION "user=DBroot password=root dbname=s1 host=127.0.0.1
port=5432"
> DATA "the_geom FROM (SELECT * FROM aree_geografiche ORDER BY
tipo_area
> DESC) AS confini USING UNIQUE gid"
> TYPE POLYGON
> STATUS ON
> # PROJECTION
> # "init=epsg:32632"
> # END
> CLASS
> NAME "States"
> STYLE
> WIDTH 3
> COLOR 194 194 194
> OUTLINECOLOR 0 0 0
> END
> END
> END
> END # Map File
> Thank you,
> Francesco.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061207/433daefe/attachment.html
