WCS Problem
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Mon Dec 11 15:03:29 EST 2006
What sort of an error message are you seeing?
>>> José Ramón López <joseramonlopez at GMAIL.COM> 12/11/2006 10:44:30 AM >>>
Hi people!
I'm trying to make a wcs service.
I've made a tile index with the ecw images that I want to populate, but I
can`t see anything in the error files.
This is my map file.
MAP
NAME PRUEBA
STATUS ON
SIZE 640 480
EXTENT 164590 4062740 579080 4266350
UNITS DD
SHAPEPATH "../data"
IMAGETYPE jpeg
FONTSET "../etc/fonts.txt"
PROJECTION
"init=epsg:23030"
END
WEB
#TEMPLATE "cursoOGC_basico.html"
IMAGEPATH "D:\ms4w\tmp"
IMAGEURL "/tmp/"
METADATA
"wcs_label" "WCS Server"
"wcs_abstract" "WCS Pruebas Server"
"wcs_version" "1.0.0"
"wcs_onlineresource" "
http://localhost:81/cgi-bin/mapserver?SERVICE=WCS"
"wcs_srs" "epsg:23030"
END
END
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 100 100 100
SIZE TINY
END
STYLE 0
SIZE 200 3
COLOR 100 100 100
OUTLINECOLOR 100 100 100
UNITS kilometers
INTERVALS 2
TRANSPARENT TRUE
STATUS on
END
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
OUTPUTFORMAT
NAME ECW
DRIVER "GDAL/ECW"
MIMETYPE "image/ecw"
IMAGEMODE "BYTE"
EXTENSION "ecw"
END
LAYER
NAME "sevilla"
STATUS ON
PROCESSING "SCALE=AUTO"
DUMP TRUE
TILEINDEX "sevilla.shp"
TILEITEM "location"
TYPE RASTER
PROJECTION
"init=epsg:23030"
END
METADATA
"wcs_description" "sevilla"
"wcs_name" "sevilla"
"wcs_label" "sevilla"
"ocs_srs" "epsg:23030"
"ows_extent" "232460 4136112 240133 4145594"
"wcs_size" "7500 9000"
"wcs_resolution" "100 100"
"wcs_bandcount" "3"
"wcs_formats" "ECW"
END
END
END
Do you know why could it be?
Thank you very much.
José Ramón López
Tfno: 627 88 88 24
