querymap with stacked points
Hal Mueller
hal at MOBILEGEOGRAPHICS.COM
Fri Dec 15 04:57:21 EST 2006
Are you using Mapscript? What is the datastore--shapefile, database, other?
There are lots of ways to do this, depending on how your app is structured.
At 10:18 AM -0600 12/13/06, Hunter, David - St. Louis Park, MN wrote:
>My map application allows users to click on
>point features, which causes a popup that
>displays information about that feature. Due to
>reasons I won't go into here, we sometimes have
>multiple points stacked on top of each other.
>They are essentially the same feature, but with
>some slightly different attributes to each
>record. Is there a way that I can filter this,
>so that only the first feature found is returned
>in the query?
>David S. Hunter
>Sr. Software Engineer
>Fidelity National Geographic Solutions
>division of Fidelity National Financial
>5353 Gamble Drive, Suite 201
>St. Louis Park, MN 55416
> Email: <mailto:david.hunter at fnf.com>david.hunter at fnf.com
>' Phone: 952.542.1440 ext. 256
>7 Fax: 952.542.3859
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061215/5ffa3cf7/attachment.html
