Raster Soviet Topo Maps
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Dec 20 00:17:35 EST 2006
Hi all,
I have downloaded some Soviet Topo maps and I want to use them with
mapserver. I can clip the collar off them, and probably shove the pixels
into a rectangle, the scans are slightly rotated.
Processing file: 050k--h36-022-2.gif
Width=2949, Height=2340
top: 2793, off: 6
right: 2192, off: -1
bottom: 2798, off: -8
right: 2190, off: 6
where the numbers above are in pixels and the off: value is offset for
that edge from horizontal or vertical wrt the opposite end.
It has corner values in lat/lons.
34.750000, 31.500000, 35.000000, 31.666667
Projection: Gauss Kruger
Datum: Pulkovo 1942
Ellipsoid: Krassovsky 1940
I assume this is a UTM projection, so how would I convert these values
for use in a wld file?
What values should go into the world file? degrees or meters?
pixel X size = 0.25 / 2793 degrees
rotation about the Y axis (usually 0.0)
rotation about the X axis (usually 0.0)
negative pixel Y size = - (10./60.) / 2192 degrees
X coordinate of upper left pixel center = 35.0 degrees
Y coordinate of upper left pixel center = 31.5 degrees
What should the mapserver projection be?
# Pulkovo 1942 / Gauss-Kruger CM 33E
<2496> +proj=tmerc +lat_0=0 +lon_0=33 +k=1.000000 +x_0=500000 +y_0=0
+ellps=krass +units=m +no_defs <>
# Pulkovo 1942 / Gauss-Kruger zone 6
<28406> +proj=tmerc +lat_0=0 +lon_0=33 +k=1.000000 +x_0=6500000 +y_0=0
# Pulkovo 1942 / Gauss-Kruger 6N
<28466> +proj=tmerc +lat_0=0 +lon_0=33 +k=1.000000 +x_0=500000 +y_0=0
or a 3-degree variant?
If I have a bunch of these, do they all need to be the same size in
pixels or can I just square up the corners as scanned and compute x-cell
size and y-cell sizes based on the scanned size?
I could use a little help on this one, I think I am close.
Thanks,
-Steve W
