***MOGELIJK SPAM*** Re: [UMN_MAPSERVER-USERS] Mapscript with
php as apache module
Eijnden, Bart van den (AGI)
b.vdeijnden at AGI.RWS.MINVENW.NL
Fri Dec 22 09:53:04 EST 2006
4.6 and 4.8 have the possible issue of non unique temp filenames.
So 4.10 is (probably) the best way to go.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Daniel Morissette
Verzonden: vrijdag 22 december 2006 15:39
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: ***MOGELIJK SPAM*** Re: [UMN_MAPSERVER-USERS] Mapscript with
Gregor Mosheh wrote:
> Reading those bugzilla entries, that's very encouraging. Thanks for
> pointing those out, Antti.
> Any "it works for me" with Unix, Apache 2 (thread or prefork), PHP 5 as a
> DSO, using a lot of PHP/Mapscript? Is there an "official" word on the
> stability of this configuration? Or am I gonna have to try it myself for a
> few days and post a "it seems to work for me"? :)
Yes, version 4.10 should be safe to use with PHP as an Apache module, I
am not aware of any outstanding issue on that front... 4.6.1 and 4.8
might be okay too, but I'm not sure, so using 4.10 is the safest way to go.
Daniel
Daniel Morissette
http://www.mapgears.com/
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
