How to Improve WMS Image Quality? - SOLVED!
Bill Thoen
bthoen at GISNET.COM
Tue Dec 26 12:45:17 EST 2006
David,
I think my biggest problem at this point in learning MapSever is not
knowing how things go together as the MapServer documentation is a bit
spotty and scattered. But you gave me the clue and by guessing I
eventually hit on defining an OUTPUTFORMAT object for gif images with
IMAGEMODE set to RGB instead of PC256. Now it looks good -- Thanks!
OUTPUTFORMAT
NAME gif
DRIVER "GD/GIF"
MIMETYPE "image/gif"
IMAGEMODE RGB
EXTENSION "gif"
END
- Bill Thoen
Fawcett, David wrote:
> Bill,
> I am guessing that you either have not designated an imagetype in your
> map file, or you are using 8 bit png or gif.
> For maps with air photos, you will likely want to use jpeg or png24.
> PNG24 looks very nice, but the output images can be pretty large and
> therefore slower to serve up.
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Bill Thoen
> Sent: Tuesday, December 26, 2006 9:32 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] How to Improve WMS Image Quality?
> After getting my last message swamped by an out-of-control
> autoresponder, I thought I'd better try again. So here's my question
> again:
> I've linked DOQ images from the Microsoft TerraServer's WMS, but they
> look terrible in my MapServer map. It looks like they are being rendered
> in 8-bit grayscale. When I display these same images with a GetMap URL
> in my browser they look fine. Could someone tell me what I need to do to
> get these to look better in MapServer?
