Java Mapscript no lib found
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Thu Feb 2 02:48:58 PST 2006
Please always add the list to your replies!
Are you using a 64 bit JVM?
Regards,
Umberto
On 2/2/06, Oliver Lichte <lichte at icbm.de> wrote:
> Yes, I am using the 64bit Version of SuSE 10.0 Linux-distr and I also
> recompiled mapserver several times with different configurations. There is no
> problem with tools like shp2img, thus the libmap.a seems to be good.
> > ldd -r libmapscript.so
>         libgd.so.2 => /usr/lib64/libgd.so.2 (0x00002aaaaacb5000)
>         libjpeg.so.62 => /usr/lib64/libjpeg.so.62 (0x00002aaaaae09000)
>         libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00002aaaaaf2a000)
>         libpng.so.3 => /usr/lib64/libpng.so.3 (0x00002aaaab0a5000)
>         libz.so.1 => /lib64/libz.so.1 (0x00002aaaab1df000)
>         libtiff.so.3 => /usr/lib64/libtiff.so.3 (0x00002aaaab2f4000)
>         libm.so.6 => /lib64/tls/libm.so.6 (0x00002aaaab44c000)
>         libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00002aaaab5a4000)
>         libc.so.6 => /lib64/tls/libc.so.6 (0x00002aaaab7a0000)
>         libXpm.so.4 => /usr/X11R6/lib64/libXpm.so.4 (0x00002aaaab9cb000)
>         libX11.so.6 => /usr/X11R6/lib64/libX11.so.6 (0x00002aaaabae2000)
>         libfontconfig.so.1 => /usr/lib64/libfontconfig.so.1
> (0x00002aaaabcf1000)
>         libpng12.so.0 => /usr/lib64/libpng12.so.0 (0x00002aaaabe30000)
>         libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002aaaabf6a000)
>         /lib64/ld-linux-x86-64.so.2 (0x0000555555554000)
>         libXext.so.6 => /usr/X11R6/lib64/libXext.so.6 (0x00002aaaac077000)
>         libdl.so.2 => /lib64/libdl.so.2 (0x00002aaaac188000)
>         libexpat.so.0 => /usr/lib64/libexpat.so.0 (0x00002aaaac28c000)
> > ldd  libmapscript.so
> Seems to be no difference.
> Oliver
> Am Donnerstag 02 Februar 2006 11:09 schrieben Sie:
> > Are you using 64bit version of the OS? If  yes did you recompile
> > mapserver or just copied it over?
> > Try to give the -r option to ldd.
> > Umberto
> Junior Research Group IMPULSE
> ICBM * Carl-v.-Ossietzky University of Oldenburg
> PO-Box 2503 * 26111 Oldenburg - Germany - http://www.icbm.de/impulse
> room: W15-2-239 * fon:+49-441-798-3622 * fax:+49-441-798-3404
More information about the MapServer-users mailing list
