tile4ms question
Jerl Simpson
jerl.simpso at GMAIL.COM
Fri Feb 3 16:48:38 EST 2006
It was the filename, I changed my program to remove the "." from the
filename and it works fine now.
thanks,
Jerl
On 2/3/06, Ed McNierney <ed at topozone.com> wrote:
> Did you look at my second question? That's a slightly funky-looking
> filename, and I would suspect that might be part of the problem unless you
> are having no trouble with similarly-named files.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
> Behalf Of *Jerl Simpson
> *Sent:* Friday, February 03, 2006 3:59 PM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] tile4ms question
> Also, ogrinfo reads it all fine, but ogr2ogr can't do anything with it
> anymore. And it was created using ogr2ogr.
> On 2/3/06, Ed McNierney < ed at topozone.com> wrote:
> > Jerl -
> > Do you have a .shx and .dbf file for it, too? Can you look at a file in
> > the same or nearby directory that DOES work to see if you can detect any
> > difference?
> > - Ed
> > Ed McNierney
> > ed at topozone.com
> > (978) 251-4242
> > *On Behalf Of *Jerl Simpson
> > *Sent:* Friday, February 03, 2006 2:37 PM
> > Just an update, I upgraded to mapserver 4.8.0 and tried using the
> > tile4ms provided, with the same result.
> > If anyone has any ideas I'd greatly appreciate any help you might be
> > able to give.
> > Thanks,
> > Jerl
> > On 2/3/06, Jerl Simpson <jerl.simpso at gmail.com> wrote:
> > > I'm not sure if this should be posted here or not, if not please point
> > > me to the right place.
> > > I'm having trouble with tile4ms opening the files from at least one of
> > > my Metafile.txt files.
> > > The command I run is as follows:
> > > tile4ms Metafile.txt tileindex
> > > error is:
> > > Aborted. Unable to open
> > > SHP:/var/mapping/tiger_2005/PriRoad/tiles/PriRoad_0037.200_-105.400
> > > I thought maybe my filename was too long, but I checked the source,
> > > 255 is the max. So I'm OK there.
> > > ogrinfo has this to say about the file:
> > > Layer name: PriRoad_0037.200_-105.400
> > > Geometry: Line String
> > > Feature Count: 459
> > > Extent: (-104.835908, 36.412144) - (-104.424129, 37.988177)
> > > Layer SRS WKT:
> > > GEOGCS["NAD83",
> > > DATUM["North_American_Datum_1983",
> > > SPHEROID["GRS 1980",6378137,298.257222101 ]],
> > > PRIMEM["Greenwich",0],
> > > UNIT["degree",0.0174532925199433]]
> > > MODULE: String (8.0)
> > > CFCC: String (3.0)
> > > FENAME: String (30.0)
> > > FETYPE: String (4.0)
> > > I'm running mapserver version 4.6.0, should I upgrade to 4.8.0?
> > > The shape is a small file, 50K, so I can provide it if need be.
> > > thanks
> > > Jerl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060203/1967dca6/attachment.html
