WFS using xml
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Feb 6 06:11:43 PST 2006
Tom,
there was a message that the CVS server is down by Steve:
Yes. Not sure why though (all parties that can do something about it are in
Chicago). It likely will not be resolved until tomorrow.
Steve
>>> Simpson <asimpson at I-55.COM> 02/04/06 10:29 AM >>>
Is http://cvs.gis.umn.edu/ down?
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: Kralidis,Tom [Burlington] [mailto:Tom.Kralidis at ec.gc.ca]
Verzonden: maandag 6 februari 2006 15:13
Aan: Eijnden, B. van den (Bart); MAPSERVER-USERS at lists.umn.edu
Onderwerp: RE: [UMN_MAPSERVER-USERS] WFS using xml
Hi Bart,
We replied almost identically and at the same time. I see great minds
think alike :)
Tell me, does MapServer CVS work for you? I can't get anything from
CVS, and wanted to check that it's not my network security before I
bother the list.
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at lists.umn.edu] On Behalf Of Eijnden,
> B. van den (Bart)
> Sent: Monday, February 06, 2006 9:04 AM
> To: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] WFS using xml
> WFS 1.0.0 in combination with GML 2.1.2. But Mapserver can
> also output GML3.
> See:
> http://mapserver.gis.umn.edu/docs/howto/wfs_server
> Best regards,
> Bart
> Van: Ricaille Tanguy [mailto:tanguy.ricaille at trasys.lu]
> Verzonden: maandag 6 februari 2006 14:50
> Aan: Eijnden, B. van den (Bart); MAPSERVER-USERS at LISTS.UMN.EDU
> Onderwerp: Re: [UMN_MAPSERVER-USERS] WFS using xml
> Hello and thanks.
> It's ok.
> Can you also tell me the version of WFS and GML supported by
> mapserver ? Best regards, Tanguy.
> ----- Original Message -----
> From: "Eijnden, B. van den (Bart)" <b.vdeijnden at AGI.RWS.MINVENW.NL>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Monday, February 06, 2006 1:44 PM
> > Yes this is possible.
> > If it does not work posting to the URL you provided, try
> posting to a
> > URL
> > like:
> > http://localhost:8089/cgi-bin/mapserv?service=WFS&version=1.0.0
> > Best regards,
> > Bart
> > Van: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Ricaille Tanguy
> > Verzonden: maandag 6 februari 2006 13:31
> > Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> > Onderwerp: [UMN_MAPSERVER-USERS] WFS using xml
> > Hello,
> > is it possible to get a feature description using POST with
> a xml file
> like
> > this:
> > <wfs:GetFeature service="WFS" version="1.0.0"
> outputFormat="GML2"...
> > xmlns=...
> > <wfs:Query typeName="featurename">
> > <ogc:Filter>
> > <ogc:BBOX>
> > <ogc:PropertyName>....
> > </wfs:GetFeature>
> > Can i post it to http://localhost:8089/cgi-bin/mapserv, and
> get back
> > description file in gml ?
> > I have a like application using geoserver, and i will try to use
> > mapserver... I hope it is possible. Thank you.
> > Disclaimer
> > Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> > uitsluitend bestemd voor de geadresseerde. Als u dit
> bericht per abuis
> > hebt ontvangen, wordt u verzocht het te vernietigen en de
> afzender te
> > informeren. Wij adviseren u om bij twijfel over de juistheid of de
> > volledigheid van de mail contact met afzender op te nemen.
> > This message shall not constitute any rights or obligations. This
> > message is intended solely for the addressee. If you have received
> > this message in error, please delete it and notify the sender
> > immediately. When in doubt whether this message is correct or
> > complete, please contact the sender.
> Disclaimer
> bericht is uitsluitend bestemd voor de geadresseerde. Als u
> dit bericht per abuis hebt ontvangen, wordt u verzocht het te
> vernietigen en de afzender te
> This message is intended solely for the addressee. If you
> have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this
> message is correct or complete, please contact the sender.
Disclaimer
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
More information about the MapServer-users
