swig mapscript interface
Tamas Szekeres
szekeres.tamas at FREEMAIL.HU
Tue Feb 7 14:01:28 PST 2006
Cris,
For C# you should access the field value by index as
string myvalue = myshape.getValue(index);
index should be less than shapeObj.numvalues.
Currently the field access by array (shapeObj.values) cannot be used due to
the absence of a C# typemap for the string array.
To access the value by field name your shape should belong to a layer.
You could achieve similar functionality as implemented in php like
if (myshape != null && mylayer != null && myshape.numvalues ==
mylayer.numvalues)
for (int i=0; i<mylayer.numitems; i++)
if (mylayer.getItem(i) == "Country_Code")
myvalue = myshape.getValue(i);
Best Regards,
Tamas Szekeres
On Mon, 6 Feb 2006 22:34:43 -0800, Christopher Condit <condit at SDSC.EDU> wrote:
>I'm curious if there's a way to get access to the shapeObj field names
>in non-PHP MapScript applications.
>In PHP, you can get a shape object (as a result of a query) and grab the
>valued of field with a string index: $myValue =
>shape.values["Country_Code"];
>I'm using c# for my application and I'm curious if there is anything
>similar - or another way to get access to the field names?
>Thanks,
>Chris
More information about the MapServer-users
