Reassign a GeoTiff color
Sage Lichtenwalner sage at MARINE.RUTGERS.EDU
Thu Feb 9 08:46:11 PST 2006
Nevermind, I just figured it out by going through the tutorial again.  For those who are curious,
the OFFSITE parameter works wonders.
Now I'm onto my next challenge of the day: figuring out the actual extents of an outputted image.
MapServer is a lot of fun once you know what you're doing!
Sage
On Thu, 9 Feb 2006 09:37:39 -0500, Sage Lichtenwalner <sage at MARINE.RUTGERS.EDU> wrote:
>Is there an easy way to reassign a color in a GeoTiff file, i.e. replacing
>"water" in a topo image with white or a color which should render as
>transparent?
>When I try to reassign a color using Class expressions, it then only
>renders colors which I specify as Classes.  I'm sure this is something
>simple, I'm just neglecting the obvious.
>Thanks,
>Sage
>Sage Lichtenwalner
>Institute of Marine and Coastal Sciences
>Rutgers, The State University of New Jersey
>71 Dudley Road, New Brunswick, NJ 08901
More information about the MapServer-users mailing list
