OGR Virtual
Mark Adams
markadams at CUESTASYS.COM
Thu Feb 9 16:11:06 EST 2006
Well, I've tried it and this is what I found:
-adding a Projection statement in the MAP file changed nothing. I added
PROJECTION elements to each layer, and played around with changing layers to
different projections - the other layers all worked fine, reprojection
worked fine etc.
-adding the EPSG in the OVF file *finally* generated an error:
[MapServer Error]: msOGRFileOpen(): Open failed for OGR connection
`parcel_test.ovf'.
Failed to import LayerSRS `EPSG:26917'.
The OVF file now looks like this:
<OGRVRTDataSource>
<OGRVRTLayer name="parcel_test">
<SrcDataSource>ODBC:parcel_test,PROPERTY_VIRTUAL</SrcDataSource>
<SrcSQL>SELECT GEOMETRY FROM PROPERTY_VIRTUAL</SrcSQL>
<GeometryType>wkbPolygon</GeometryType>
<GeometryField encoding="WKT" field="GEOMETRY"/>
<LayerSRS>EPSG:26917</LayerSRS>
</OGRVRTLayer>
</OGRVRTDataSource>
I don't know why this would fail: the epsg file in proj\nad folder has this
code defined, and mapserver is able to use it for the other layers (which
are shapefiles).
Any thoughts?
Thanks for your help so far.
Mark Adams
Senior Analyst & Project Manager
Cuesta Systems (DPRA Canada)
5230 South Service Road
Burlington, ON L7L 5K2
Phone: 905-333-4544 x14
Fax: 905-333-0455
Email: mark.adams at dpra.com
-----Original Message-----
Sent: February 9, 2006 3:57 PM
To: Mark Adams; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] OGR Virtual
Hello Mark,
You are correct with your explanation about PROJECTION but since I had this
case last year where I did have to add PROJECTION to an OVF layer although
all data was in the same projection I thought it might be worth trying it.
However, I have not fully test cased this and I don't know enough about the
underlying code to be sure this was the (right) solution to the problem.
Regards,
Emil
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Mark Adams
Sent: donderdag 9 februari 2006 21:44
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] OGR Virtual
I will try that. However, my understanding of PROJECTION is that it is not
required unless you have data in more than one projection, or want to
display the data in a projection different from the one the data is in. Is
that not correct?
Thanks.
Mark Adams
Fax: 905-333-0455
Sent: February 9, 2006 3:41 PM
Hello Mark,
Have you tried adding a PROJECTION to the LAYER containing the ovf file
and/or the ovf file?
Something like:
LAYER
NAME "Virtual Parcel"
DEBUG ON
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "parcel_test.ovf"
DATA "parcel_test"
TYPE POLYGON
# fill projection parameter, e.g. 28992 for Dutch system
PROJECTION
"init=epsg:12345"
END
TEMPLATE "null"
CLASS
STYLE
COLOR 255 1 5
OUTLINECOLOR 168 112 0
END
END
END
In the past I had situations where I needed to put the PROJECTION in the
LAYER and not in the OVF file.
Also, use STATUS DEFAULT for testing purposes so the layer is always on.
Regards,
Emil
Sent: donderdag 9 februari 2006 21:12
Hello,
I would like to know if there was ever a successful resolution to Frank's
question below. I am in the same situation: I cannot get the OGR virtual
layer to render on my map.
I have had no problem with points. However when I try to render a virtual
polygon I get no error, just no feature on the map. The other layers all
render without problem. I get no error from OGRINFO either.
I've tried a number of different ways of configuring the OVF file, the
data in the database, and the MAP file. Numerous combinations result
in "success" in the sense of no errors, but still no features.
Here is my most recent attempt:
Connection: I'm using an ODBC connection to an MS Access database. The
ODBC connection is called "parcel_test".
OVF:
<OGRVRTDataSource>
</OGRVRTLayer>
</OGRVRTDataSource>
MAP:
LAYER
DEBUG ON
STATUS ON
CONNECTIONTYPE OGR
DATA "parcel_test"
TYPE POLYGON
TEMPLATE "null"
CLASS
STYLE
COLOR 255 1 5
END
END
END
I've got one record in the PROPERTY_VIRTUAL table, with the GEOMETRY value
set as follows:
POLYGON('501453.34 4800585.97,501576.14 4800590.44,501569.85
4800522,501471.61 4800521.63,501453.34 4800585.97')
I've also tried storing the geometry without the quotes, brackets, and
keyword POLYGON but it doesn't change the result.
I've captured this output when I refresh the map:
msOGRFileOpen(parcel_test.ovf)...
OGROPen
(\\Snow\c_drive\Inetpub\wwwroot\NTGO_GeoPortal\config\..\Data\Shapefiles/pa
rcel_test.ovf)
msOGRLayerClose(parcel_test.ovf).
msOGRFileClose
rcel_test.ovf,0).
msDrawMap(): Layer 3 (Virtual Parcel), 0.130s
msDrawMap(): Layer 4 (Property Parcels), 0.101s
msDrawMap(): Layer 6 (Streets), 0.030s
msDrawMap(): Drawing Label Cache, 0.000s
msDrawMap() total time: 0.281s
OGROPen
rcel_test.ovf)
msOGRFileClose
rcel_test.ovf,0).
msDrawMap(): Layer 3 (Virtual Parcel), 0.110s
msDrawMap(): Layer 4 (Property Parcels), 0.070s
msDrawMap() total time: 0.220s
>From the FWTools command line I get this:
C:\Program Files\FWTools1.0.0a7>ogrinfo ODBC:parcel_test
INFO: Open of `ODBC:parcel_test'
using driver `ODBC' successful.
1: PROPERTY_VIRTUAL
C:\Program Files\FWTools1.0.0a7>ogrinfo ODBC:parcel_test PROPERTY_VIRTUAL
Layer name: PROPERTY_VIRTUAL
Geometry: Unknown (any)
Feature Count: 1
Layer SRS WKT:
(unknown)
OBJECTID: Integer (10.0)
STATUS: String (20.0)
UTM_X: Real (0.0)
UTM_Y: Real (0.0)
AREA: Real (0.0)
SHAPE_Length: Real (0.0)
SHAPE_Area: Real (0.0)
HERITAGE: String (20.0)
PAR_UPDATE: String (10.0)
UPDATE_DATE: String (20.0)
CREATE_DATE: String (20.0)
UPDATE_SOURCE: String (50.0)
AREA_ACRE: Real (0.0)
PID: Integer (10.0)
AREA_HECTARE: Real (0.0)
OGRFeature(PROPERTY_VIRTUAL):0
OBJECTID (Integer) = 2
STATUS (String) = Active
UTM_X (Real) = 501405.687500125
UTM_Y (Real) = 4801949.24999883
AREA (Real) = 229.843703627485
SHAPE_Length (Real) = 77.3317483960398
SHAPE_Area (Real) = 229.843703627485
HERITAGE (String) = PART V
PAR_UPDATE (String) = (null)
UPDATE_DATE (String) = (null)
CREATE_DATE (String) = (null)
UPDATE_SOURCE (String) = (null)
AREA_ACRE (Real) = 0.0567943791663515
PID (Integer) = 42385
AREA_HECTARE (Real) = 0.0229843703627485
Any help would be greatly appreciated. I have several polygon layers to
publish this way, ultimately from an Oracle database.
Thanks in advance,
Mark Adams
Fax: 905-333-0455
On Wed, 21 Dec 2005 00:10:06 -0600, Frank Fica <simbiotico at HOTMAIL.COM>
wrote:
>Hello,
>I've been trying to map a non-spatial postgre table with ogr via ODBC but
no success. There must
>be a simple solution to what I'm missing and I haven't been able to
figure it out. My other layers
>do render but my Virtual layer doesn't. When I test in ogrinfo I can
connect but when I try to map
>in mapserver the image is blank, only my mapinfo layer renders.
>Does someone has any suggestions on what I'm missing?
>Here are is my ovf file:
><OGRVRTDataSource>
> <OGRVRTLayer name="sorento">
> <SrcDataSource>ODBC:@PostgreSQL,sorento</SrcDataSource>
> <SrcLayer>sorento</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="Lon" y="Lat"/>
> </OGRVRTLayer>
></OGRVRTDataSource>
>and map file:
>MAP
> IMAGETYPE PNG
> EXTENT -90.760314 14.252771 -90.210352 14.937117
> SIZE 640 480
> UNITS METERS
> SYMBOL
> NAME "circle"
> TYPE ELLIPSE
> POINTS
> 1 1
> END
> FILLED TRUE
> END
> LAYER
> NAME "ciudad"
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "/var/www/html/guatemala/data/ciudad.tab"
> STYLEITEM "AUTO"
> CLASS
> NAME "Ciudad"
> END
> END
> LAYER
> NAME "sorento"
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "virtual.ovf"
> DATA "sorento"
> STATUS DEFAULT
> CLASS
> STYLE
> SYMBOL 'circle'
> SIZE 30
> COLOR 255 0 0
> END
> END
> END
>END
