Online raster processing?
Teemu Makela
teemu.makela at ARBONAUT.COM
Fri Feb 10 09:57:15 EST 2006
In MapServer Documentation "Raster Data Access" is a following example:
"CLASS
NAME "near white"
EXPRESSION ([red] > 200 AND [green] > 200 AND [blue] > 200)
STYLE
COLOR 0 255 0
END
END"
However, it is also stated that "Raster classifications always take place on
only one raster band. It defaults to the first band in the referenced file,
but this can be altered with the BANDS PROCESSING directive."
IS IT POSSIBLE TO CLASSIFY SEVERAL BANDS?
My problem:
I have large set of aerial images. Map file, which work fine:
"LAYER
NAME "Aerial images"
TYPE RASTER
STATUS ON
MINSCALE 40
MAXSCALE 50000
PROJECTION
"init=epsg:2393"
END
TILEINDEX "ilmakuvat.shp" #image format is ECW
END"
I need to reclassify images online so that near white colors would be set to
250,250,250. So, I tried this:
LAYER
NAME "Classified"
TYPE RASTER
STATUS ON
MINSCALE 40
MAXSCALE 50000
PROJECTION
"init=epsg:2393"
END
PROCESSING "BANDS=1,2,3"
CLASS
NAME "near white"
EXPRESSION ([red] > 250 AND [green] > 250 AND [blue] > 250)
STYLE
COLOR 250 250 250
END
END
END
But it does not work.
Alone "PROCESSING "BANDS=1,2,3" or "PROCESSING "BANDS=3,2,1" work fine and
produces images with different color scheme.
PROCESSING with one (1) band only works with CLASS definition. So map file:
"PROCESSING "BANDS=2"
CLASS
NAME "near white"
STYLE
COLOR 250 250 250
END
END"
Generates an image with some red pixels, otherwise white. This is fine.
However, if there is CLASS definition and PROCESSING of several bands
(PROCESSING "BANDS=1,2,3") at the same time no image is generated.
What should I do?
Teemu
