Raster Re-projection
Christopher Condit
condit at SDSC.EDU
Fri Feb 10 19:38:47 EST 2006
I've got a mapfile that draws perfectly in epsg:4326 - with both raster
and vector data (also in epsg:4326).
Under certain application conditions, I need to re-project the map into
a polar view. To do this I change projection string to
PROJECTION
"proj=laea"
"lat_0=-90"
END
This works very well for all of my vector data, but none of my raster
data appears. The raster data is in AAI/Grid format. Will this raster
format not re-project? Should I use a different polar projection?
Thanks!
Chris
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060210/c6cf9dba/attachment.html
