Crash with query
Jelmer Baas
baas at SPEERIT.NL
Mon Feb 13 10:02:04 EST 2006
Dear all,
Once again, I have a problem. I finally stopped using the .tab files and
switched to the "live" Oracle data. Everything goes well, until I run a
query (to find out what's underneath my mousepointer).
My Query:
http://loopplank/coconjb/scripts/mapserv.exe?mode=nquery&map=../query.map&imgext=189991.7+443456.5375+191827.6+444833.4625&imgxy=339+209&imgbox=329+199+349+219&layers=netherlands+TABCAB
The query.map file is brand new, specially made this query (to test), my
symbol set is also OK. It's really when I switch from .tab files to
Oracle that it does wrong. And yes, MapServer *does* display the lines
properly (i.e., no crash with same .map & .sym files).
How can I find out how, where and why this goes wrong? I only get a "The
instruction at <some address> referenced memory at <some address>. The
memory could not be "read"."
I'll try to install a debugger, though I doubt that would do anyone any
good. Running "Hobu's kitchen sink MapServer 4.6" binaries on WinXP.
Jelmer
