wms howto
    Bart van den Eijnden (OSGIS)
    bartvde at XS4ALL.NL
    Wed Feb 15 11:05:52 PST 2006
There is no status in WMS, only in a Web Map Context (WMC) document
status is defined. The status is up to the WMS client and not to the WMS
server.
wms_extent is mentioned in the docs:
http://mapserver.gis.umn.edu/docs/howto/wms_server/
Best regards,
Bart
Travis Kirstine GIS Tech wrote:
>Bart,
>Your suggestion worked like a charm.  Do you know where I could find a
>complete list of wms commands.  I've tried the mapserver documentation but
>it dosen't include wms_extent for example.  I've tried to set the status off
>using "wms_status" "off" but that dosen't work
>-----Original Message-----
>From: Bart van den Eijnden (OSGIS) [mailto:bartvde at xs4all.nl]
>Sent: Wednesday, February 15, 2006 12:39 PM
>To: Travis Kirstine GIS Tech
>Cc: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] wms extent
>Yes there is, set the wms_extent METADATA on that LAYER.
>Best regards,
>Bart
>>When I add a mapserver based wms to ArcMap or uDig the map extent defaults
>>to the max xy and min xy of my largest layer in my mapfile (Ontario)instead
>>of the extent defined in my mapfile (toronto).  Is there a way to force the
>>EXTENT defined in the mapfile?
>>Travis Kirstine
>>First Base Solutions Limited
>>140 Renfrew Dr, Suite 100
>>Markham ON
>>L3R 6B3
>>Phone 905.477.3600
>>Fax 905.477.3882
>>tkirstine at jdbarnes.com
>OSGIS, Open Source GIS
>http://www.osgis.nl
http://www.osgis.nl
More information about the MapServer-users
