Help with projection
Luis Trevi ño
ltrevino at GPOBSI.COM.MX
Thu Feb 16 14:44:12 PST 2006
Hi list,
some questions:
I´m building an aplication that draws some GPS points over a map. this
point are beeing updated on a postgis table. My data source is a shape
file, this data needs to be adjusted about 180 meters on the latitude
values (the data source was made with proj=utm and datum=NAD27).
I've tried using diferent input projections in order to see if mapserver
can adjust this data but I can´t get good results.
My output projection is:
PROJECTION
"proj=utm"
"ellps=WGS84"
"datum=WGS84"
END
Could some projection help to adjust this 180 meters on the latitud?
If I transfer my shape data to postgis using a specific SRID, would help?
How can I build a specific SRID?
regards,
Luis
More information about the MapServer-users
