GD LIBRARY
Nikos
nicolas at MAICH.GR
Fri Feb 17 03:51:06 EST 2006
Fabio D' Ovidio wrote:
> Dear list,
> I want to compile GD library on windows 2000.
> The zip package has only the DLL and a .bat file to convert the dll in
> lib for mapserver.
> I'd like to compile GD from source (because I have to use a different
> compiler and linker)
> so I need the source files for Windows and \ or a makefile.
> How can I do ?
Below is a config.status file used for compiling gd-2.0.15 under
msys/mingw.....
hope this helps...
regards,
nikos
> Thank u
> */Fabio D'Ovidio/*
> */Planetek Italia Srl/*
> */via Massaua 12, Bari -70123 Italy/*
> */e-mail : /**/_dovidio at planetek.it_/*
> */_http://www.planetek.it_/*
#! /bin/sh
# Generated by configure.
# Run this file to recreate the current configuration.
# Compiler output produced by configure, useful for debugging
# configure, is in config.log if it exists.
debug=false
ac_cs_recheck=false
ac_cs_silent=false
SHELL=${CONFIG_SHELL-/bin/sh}
## M4sh Initialization. ##
# Be Bourne compatible
if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
emulate sh
NULLCMD=:
# Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
# is contrary to our usage. Disable this feature.
alias -g '${1+"$@"}'='"$@"'
elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
set -o posix
fi
# Support unset when possible.
if (FOO=FOO; unset FOO) >/dev/null 2>&1; then
as_unset=unset
else
as_unset=false
fi
# Work around bugs in pre-3.0 UWIN ksh.
$as_unset ENV MAIL MAILPATH
PS1='$ '
PS2='> '
PS4='+ '
# NLS nuisances.
for as_var in \
LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
LC_TELEPHONE LC_TIME
do
if (set +x; test -n "`(eval $as_var=C; export $as_var) 2>&1`"); then
else
$as_unset $as_var
fi
done
# Required to use basename.
if expr a : '\(a\)' >/dev/null 2>&1; then
as_expr=expr
else
as_expr=false
fi
if (basename /) >/dev/null 2>&1 && test "X`basename / 2>&1`" = "X/"; then
as_basename=basename
else
as_basename=false
fi
# Name of the executable.
as_me=`$as_basename "$0" ||
$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
X"$0" : 'X\(//\)$' \| \
X"$0" : 'X\(/\)$' \| \
. : '\(.\)' 2>/dev/null ||
echo X/"$0" |
sed '/^.*\/\([^/][^/]*\)\/*$/{ s//\1/; q; }
/^X\/\(\/\/\)$/{ s//\1/; q; }
/^X\/\(\/\).*/{ s//\1/; q; }
s/.*/./; q'`
# PATH needs CR, and LINENO needs CR and PATH.
# Avoid depending upon Character Ranges.
as_cr_letters='abcdefghijklmnopqrstuvwxyz'
as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
as_cr_Letters=$as_cr_letters$as_cr_LETTERS
as_cr_digits='0123456789'
as_cr_alnum=$as_cr_Letters$as_cr_digits
# The user is always right.
if test "${PATH_SEPARATOR+set}" != set; then
echo "#! /bin/sh" >conf$$.sh
echo "exit 0" >>conf$$.sh
chmod +x conf$$.sh
if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
PATH_SEPARATOR=';'
else
PATH_SEPARATOR=:
fi
rm -f conf$$.sh
fi
as_lineno_1=$LINENO
as_lineno_2=$LINENO
as_lineno_3=`(expr $as_lineno_1 + 1) 2>/dev/null`
test "x$as_lineno_1" != "x$as_lineno_2" &&
test "x$as_lineno_3" = "x$as_lineno_2" || {
# Find who we are. Look in the path if we contain no path at all
# relative or not.
case $0 in
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
done
esac
# We did not find ourselves, most probably we were run as `sh COMMAND'
# in which case we are not to be found in the path.
if test "x$as_myself" = x; then
as_myself=$0
fi
if test ! -f "$as_myself"; then
{ { echo "$as_me:$LINENO: error: cannot find myself; rerun with an
absolute path" >&5
echo "$as_me: error: cannot find myself; rerun with an absolute path" >&2;}
{ (exit 1); exit 1; }; }
fi
case $CONFIG_SHELL in
for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
do
IFS=$as_save_IFS
for as_base in sh bash ksh sh5; do
case $as_dir in
if ("$as_dir/$as_base" -c '
as_lineno_1=$LINENO
as_lineno_2=$LINENO
test "x$as_lineno_3" = "x$as_lineno_2" ') 2>/dev/null; then
$as_unset BASH_ENV || test "${BASH_ENV+set}" != set || {
BASH_ENV=; export BASH_ENV; }
$as_unset ENV || test "${ENV+set}" != set || { ENV=; export ENV; }
CONFIG_SHELL=$as_dir/$as_base
export CONFIG_SHELL
exec "$CONFIG_SHELL" "$0" ${1+"$@"}
fi;;
esac
done
done
esac
# Create $as_me.lineno as a copy of $as_myself, but with $LINENO
# uniformly replaced by the line number. The first 'sed' inserts a
# line-number line before each line; the second 'sed' does the real
# work. The second script uses 'N' to pair each line-number line
# with the numbered line, and appends trailing '-' during
# substitution so that $LINENO is not a special case at line end.
# (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
# second 'sed' script. Blame Lee E. McMahon for sed's syntax. :-)
sed '=' <$as_myself |
sed '
N
s,$,-,
: loop
s,^\(['$as_cr_digits']*\)\(.*\)[$]LINENO\([^'$as_cr_alnum'_]\),\1\2\1\3,
t loop
s,-$,,
s,^['$as_cr_digits']*\n,,
' >$as_me.lineno &&
chmod +x $as_me.lineno ||
{ { echo "$as_me:$LINENO: error: cannot create $as_me.lineno; rerun
with a POSIX shell" >&5
echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX
shell" >&2;}
# Don't try to exec as it changes $[0], causing all sort of problems
# (the dirname of $[0] is not the place where we might find the
# original and so on. Autoconf is especially sensible to this).
. ./$as_me.lineno
# Exit status is that of the last command.
exit
case `echo "testing\c"; echo 1,2,3`,`echo -n testing; echo 1,2,3` in
*c*,-n*) ECHO_N= ECHO_C='
' ECHO_T=' ' ;;
*c*,* ) ECHO_N=-n ECHO_C= ECHO_T= ;;
*) ECHO_N= ECHO_C='\c' ECHO_T= ;;
esac
as_expr=expr
else
as_expr=false
fi
rm -f conf$$ conf$$.exe conf$$.file
echo >conf$$.file
if ln -s conf$$.file conf$$ 2>/dev/null; then
# We could just check for DJGPP; but this test a) works b) is more generic
# and c) will remain valid once DJGPP supports symlinks (DJGPP 2.04).
if test -f conf$$.exe; then
# Don't use ln at all; we don't have any links
as_ln_s='cp -p'
else
as_ln_s='ln -s'
fi
elif ln conf$$.file conf$$ 2>/dev/null; then
as_ln_s=ln
else
as_ln_s='cp -p'
fi
if mkdir -p . 2>/dev/null; then
as_mkdir_p=:
else
as_mkdir_p=false
fi
as_executable_p="test -f"
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="sed y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g"
# Sed expression to map a string onto a valid variable name.
as_tr_sh="sed y%*+%pp%;s%[^_$as_cr_alnum]%_%g"
# IFS
# We need space, tab and new line, in precisely that order.
as_nl='
IFS=" $as_nl"
# CDPATH.
$as_unset CDPATH
exec 6>&1
# Open the log real soon, to keep \$[0] and so on meaningful, and to
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling. Logging --version etc. is OK.
exec 5>>config.log
echo
sed 'h;s/./-/g;s/^.../## /;s/...$/ ##/;p;x;p;x' <<_ASBOX
## Running $as_me. ##
_ASBOX
} >&5
cat >&5 <<_CSEOF
This file was extended by GD $as_me 2.0.15, which was
generated by GNU Autoconf 2.57. Invocation command line was
CONFIG_FILES = $CONFIG_FILES
CONFIG_HEADERS = $CONFIG_HEADERS
CONFIG_LINKS = $CONFIG_LINKS
CONFIG_COMMANDS = $CONFIG_COMMANDS
$ $0 $@
_CSEOF
echo "on `(hostname || uname -n) 2>/dev/null | sed 1q`" >&5
echo >&5
config_files=" Makefile config/Makefile config/gdlib-config test/Makefile"
config_headers=" config.h:config.hin"
config_commands=" depfiles"
ac_cs_usage="\
\`$as_me' instantiates files from templates according to the
Usage: $0 [OPTIONS] [FILE]...
-h, --help print this help, then exit
-V, --version print version number, then exit
-q, --quiet do not print progress messages
-d, --debug don't remove temporary files
--recheck update $as_me by reconfiguring in the same conditions
--file=FILE[:TEMPLATE]
instantiate the configuration file FILE
--header=FILE[:TEMPLATE]
instantiate the configuration header FILE
Configuration files:
$config_files
Configuration headers:
$config_headers
Configuration commands:
$config_commands
Report bugs to <bug-autoconf at gnu.org>."
ac_cs_version="\
GD config.status 2.0.15
configured by ./configure, generated by GNU Autoconf 2.57,
with options \"'--with-png=../libpng-1.2.5'
'--with-freetype=../freetype-2.1.5' '--with-jpeg=../jpeg-6b'
'--with-gif' '--prefix=/mingw'\"
Copyright 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001
Free Software Foundation, Inc.
This config.status script is free software; the Free Software Foundation
gives unlimited permission to copy, distribute and modify it."
srcdir=.
INSTALL="/bin/install -c"
# If no file are specified by the user, then we need to provide default
# value. By we need to know if files were specified by the user.
ac_need_defaults=:
while test $# != 0
do
case $1 in
ac_option=`expr "x$1" : 'x\([^=]*\)='`
ac_optarg=`expr "x$1" : 'x[^=]*=\(.*\)'`
ac_shift=:
ac_option=$1
ac_optarg=$2
ac_shift=shift
*) # This is not an option, so the user has probably given explicit
# arguments.
ac_option=$1
ac_need_defaults=false;;
esac
case $ac_option in
# Handling of the options.
-recheck | --recheck | --rechec | --reche | --rech | --rec | --re | --r)
ac_cs_recheck=: ;;
--version | --vers* | -V )
echo "$ac_cs_version"; exit 0 ;;
--he | --h)
# Conflict between --help and --header
{ { echo "$as_me:$LINENO: error: ambiguous option: $1
Try \`$0 --help' for more information." >&5
echo "$as_me: error: ambiguous option: $1
Try \`$0 --help' for more information." >&2;}
{ (exit 1); exit 1; }; };;
--help | --hel | -h )
echo "$ac_cs_usage"; exit 0 ;;
--debug | --d* | -d )
debug=: ;;
--file | --fil | --fi | --f )
$ac_shift
CONFIG_FILES="$CONFIG_FILES $ac_optarg"
--header | --heade | --head | --hea )
$ac_shift
CONFIG_HEADERS="$CONFIG_HEADERS $ac_optarg"
-q | -quiet | --quiet | --quie | --qui | --qu | --q \
| -silent | --silent | --silen | --sile | --sil | --si | --s)
ac_cs_silent=: ;;
# This is an error.
-*) { { echo "$as_me:$LINENO: error: unrecognized option: $1
echo "$as_me: error: unrecognized option: $1
{ (exit 1); exit 1; }; } ;;
*) ac_config_targets="$ac_config_targets $1" ;;
esac
shift
done
ac_configure_extra_args=
if $ac_cs_silent; then
exec 6>/dev/null
ac_configure_extra_args="$ac_configure_extra_args --silent"
fi
if $ac_cs_recheck; then
echo "running /bin/sh ./configure " '--with-png=../libpng-1.2.5'
'--with-gif' '--prefix=/mingw' $ac_configure_extra_args " --no-create
--no-recursion" >&6
exec /bin/sh ./configure '--with-png=../libpng-1.2.5'
'--with-gif' '--prefix=/mingw' $ac_configure_extra_args --no-create
--no-recursion
fi
# INIT-COMMANDS section.
AMDEP_TRUE="" ac_aux_dir="config"
for ac_config_target in $ac_config_targets
do
case "$ac_config_target" in
# Handling of arguments.
"Makefile" ) CONFIG_FILES="$CONFIG_FILES Makefile" ;;
"config/Makefile" ) CONFIG_FILES="$CONFIG_FILES config/Makefile" ;;
"config/gdlib-config" ) CONFIG_FILES="$CONFIG_FILES
config/gdlib-config" ;;
"test/Makefile" ) CONFIG_FILES="$CONFIG_FILES test/Makefile" ;;
"depfiles" ) CONFIG_COMMANDS="$CONFIG_COMMANDS depfiles" ;;
"config.h" ) CONFIG_HEADERS="$CONFIG_HEADERS config.h:config.hin" ;;
*) { { echo "$as_me:$LINENO: error: invalid argument:
$ac_config_target" >&5
echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
esac
done
# If the user did not use the arguments to specify the items to instantiate,
# then the envvar interface is used. Set only those that are not.
# We use the long form for the default assignment because of an extremely
# bizarre bug on SunOS 4.1.3.
if $ac_need_defaults; then
test "${CONFIG_FILES+set}" = set || CONFIG_FILES=$config_files
test "${CONFIG_HEADERS+set}" = set || CONFIG_HEADERS=$config_headers
test "${CONFIG_COMMANDS+set}" = set || CONFIG_COMMANDS=$config_commands
fi
# Have a temporary directory for convenience. Make it in the build tree
# simply because there is no reason to put it here, and in addition,
# creating and moving files from /tmp can sometimes cause problems.
# Create a temporary directory, and hook for its removal unless debugging.
$debug ||
trap 'exit_status=$?; rm -rf $tmp && exit $exit_status' 0
trap '{ (exit 1); exit 1; }' 1 2 13 15
# Create a (secure) tmp directory for tmp files.
tmp=`(umask 077 && mktemp -d -q "./confstatXXXXXX") 2>/dev/null` &&
test -n "$tmp" && test -d "$tmp"
tmp=./confstat$$-$RANDOM
(umask 077 && mkdir $tmp)
echo "$me: cannot create a temporary directory in ." >&2
# CONFIG_FILES section.
# No need to generate the scripts if there are no CONFIG_FILES.
# This happens for instance when ./config.status config.h
if test -n "$CONFIG_FILES"; then
# Protect against being on the right side of a sed subst in config.status.
sed 's/,@/@@/; s/@,/@@/; s/,;t t$/@;t t/; /@;t t$/s/[\\&,]/\\&/g;
s/@@/,@/; s/@@/@,/; s/@;t t$/,;t t/' >$tmp/subs.sed <<\CEOF
s, at SHELL@,/bin/sh,;t t
s, at PATH_SEPARATOR@,:,;t t
s, at PACKAGE_NAME@,GD,;t t
s, at PACKAGE_TARNAME@,gd,;t t
s, at PACKAGE_VERSION@,2.0.15,;t t
s, at PACKAGE_STRING@,GD 2.0.15,;t t
s, at PACKAGE_BUGREPORT@,gd at boutell.com,;t t
s, at exec_prefix@,${prefix},;t t
s, at prefix@,/mingw,;t t
s, at program_transform_name@,s,x,x,,;t t
s, at bindir@,${exec_prefix}/bin,;t t
s, at sbindir@,${exec_prefix}/sbin,;t t
s, at libexecdir@,${exec_prefix}/libexec,;t t
s, at datadir@,${prefix}/share,;t t
s, at sysconfdir@,${prefix}/etc,;t t
s, at sharedstatedir@,${prefix}/com,;t t
s, at localstatedir@,${prefix}/var,;t t
s, at libdir@,${exec_prefix}/lib,;t t
s, at includedir@,${prefix}/include,;t t
s, at oldincludedir@,/usr/include,;t t
s, at infodir@,${prefix}/info,;t t
s, at mandir@,${prefix}/man,;t t
s, at build_alias@,,;t t
s, at host_alias@,,;t t
s, at target_alias@,,;t t
s, at DEFS@,-DHAVE_CONFIG_H,;t t
s, at ECHO_C@,,;t t
s, at ECHO_N@,-n,;t t
s, at ECHO_T@,,;t t
s, at LIBS@,-ljpeg -lfreetype -lpng -lz ,;t t
s, at GDLIB_MAJOR@,2,;t t
s, at GDLIB_MINOR@,0,;t t
s, at GDLIB_REVISION@,15,;t t
s, at GDLIBNAME@,gd,;t t
s, at INSTALL_PROGRAM@,${INSTALL},;t t
s, at INSTALL_SCRIPT@,${INSTALL},;t t
s, at INSTALL_DATA@,${INSTALL} -m 644,;t t
s, at CYGPATH_W@,echo,;t t
s, at PACKAGE@,gd,;t t
s, at VERSION@,2.0.15,;t t
s, at ACLOCAL@,${SHELL} /home/adonis/build/gd-2.0.15/config/missing --run
aclocal-1.7,;t t
s, at AUTOCONF@,${SHELL} /home/adonis/build/gd-2.0.15/config/missing --run
autoconf,;t t
s, at AUTOMAKE@,${SHELL} /home/adonis/build/gd-2.0.15/config/missing --run
automake-1.7,;t t
s, at AUTOHEADER@,${SHELL} /home/adonis/build/gd-2.0.15/config/missing
--run autoheader,;t t
s, at MAKEINFO@,${SHELL} /home/adonis/build/gd-2.0.15/config/missing --run
makeinfo,;t t
s, at AMTAR@,${SHELL} /home/adonis/build/gd-2.0.15/config/missing --run
tar,;t t
s, at install_sh@,/home/adonis/build/gd-2.0.15/config/install-sh,;t t
s, at STRIP@,strip,;t t
s, at ac_ct_STRIP@,strip,;t t
s, at INSTALL_STRIP_PROGRAM@,${SHELL} $(install_sh) -c -s,;t t
s, at AWK@,gawk,;t t
s, at SET_MAKE@,,;t t
s, at CC@,gcc,;t t
s, at CFLAGS@,-g -O2,;t t
s, at LDFLAGS@, -L/mingw/lib -L/mingw/lib -Wl,-rpath,/mingw/lib
-L../jpeg-6b/lib,;t t
s, at CPPFLAGS@,-I/mingw/include/freetype2 -I/mingw/include
-I../freetype-2.1.5/include -I/mingw/include/libpng12
-DPNG_THREAD_UNSAFE_OK -DPNG_USE_PNGGCCRD -I../jpeg-6b/include,;t t
s, at ac_ct_CC@,gcc,;t t
s, at EXEEXT@,.exe,;t t
s, at OBJEXT@,o,;t t
s, at DEPDIR@,.deps,;t t
s, at am__include@,include,;t t
s, at am__quote@,,;t t
s, at AMDEP_TRUE@,,;t t
s, at AMDEP_FALSE@,#,;t t
s, at AMDEPBACKSLASH@,\,;t t
s, at CCDEPMODE@,depmode=gcc3,;t t
s, at am__fastdepCC_TRUE@,,;t t
s, at am__fastdepCC_FALSE@,#,;t t
s, at build@,i686-pc-mingw32,;t t
s, at build_cpu@,i686,;t t
s, at build_vendor@,pc,;t t
s, at build_os@,mingw32,;t t
s, at host@,i686-pc-mingw32,;t t
s, at host_cpu@,i686,;t t
s, at host_vendor@,pc,;t t
s, at host_os@,mingw32,;t t
s, at LN_S@,ln -s,;t t
s, at ECHO@,echo,;t t
s, at RANLIB@,ranlib,;t t
s, at ac_ct_RANLIB@,ranlib,;t t
s, at CPP@,gcc -E,;t t
s, at EGREP@,grep -E,;t t
s, at LIBTOOL@,$(SHELL) $(top_builddir)/libtool,;t t
s, at LIBICONV@,,;t t
s, at LTLIBICONV@,,;t t
s, at LIBPNG_CONFIG@,/mingw/bin/libpng-config,;t t
s, at FREETYPE_CONFIG@,/mingw/bin/freetype-config,;t t
s, at LIBOBJS@,,;t t
s, at LTLIBOBJS@,,;t t
CEOF
# Split the substitutions into bite-sized pieces for seds with
# small command number limits, like on Digital OSF/1 and HP-UX.
ac_max_sed_lines=48
ac_sed_frag=1 # Number of current file.
ac_beg=1 # First line for current file.
ac_end=$ac_max_sed_lines # Line after last line for current file.
ac_more_lines=:
ac_sed_cmds=
while $ac_more_lines; do
if test $ac_beg -gt 1; then
sed "1,${ac_beg}d; ${ac_end}q" $tmp/subs.sed >$tmp/subs.frag
else
sed "${ac_end}q" $tmp/subs.sed >$tmp/subs.frag
fi
if test ! -s $tmp/subs.frag; then
ac_more_lines=false
else
# The purpose of the label and of the branching condition is to
# speed up the sed processing (if there are no `@' at all, there
# is no need to browse any of the substitutions).
# These are the two extra sed commands mentioned above.
(echo ':t
/@[a-zA-Z_][a-zA-Z_0-9]*@/!b' && cat $tmp/subs.frag)
>$tmp/subs-$ac_sed_frag.sed
if test -z "$ac_sed_cmds"; then
ac_sed_cmds="sed -f $tmp/subs-$ac_sed_frag.sed"
else
ac_sed_cmds="$ac_sed_cmds | sed -f $tmp/subs-$ac_sed_frag.sed"
fi
ac_sed_frag=`expr $ac_sed_frag + 1`
ac_beg=$ac_end
ac_end=`expr $ac_end + $ac_max_sed_lines`
fi
done
ac_sed_cmds=cat
fi
fi # test -n "$CONFIG_FILES"
for ac_file in : $CONFIG_FILES; do test "x$ac_file" = x: && continue
# Support "outfile[:infile[:infile...]]", defaulting infile="outfile.in".
case $ac_file in
- | *:- | *:-:* ) # input from stdin
cat >$tmp/stdin
ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
ac_file=`echo "$ac_file" | sed 's,:.*,,'` ;;
*:* ) ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
* ) ac_file_in=$ac_file.in ;;
esac
# Compute @srcdir@, @top_srcdir@, and @INSTALL@ for subdirectories.
ac_dir=`(dirname "$ac_file") 2>/dev/null ||
$as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
X"$ac_file" : 'X\(//\)[^/]' \| \
X"$ac_file" : 'X\(//\)$' \| \
X"$ac_file" : 'X\(/\)' \| \
echo X"$ac_file" |
sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
/^X\(\/\/\)[^/].*/{ s//\1/; q; }
/^X\(\/\/\)$/{ s//\1/; q; }
/^X\(\/\).*/{ s//\1/; q; }
s/.*/./; q'`
{ if $as_mkdir_p; then
mkdir -p "$ac_dir"
else
as_dir="$ac_dir"
as_dirs=
while test ! -d "$as_dir"; do
as_dirs="$as_dir $as_dirs"
as_dir=`(dirname "$as_dir") 2>/dev/null ||
$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
X"$as_dir" : 'X\(//\)[^/]' \| \
X"$as_dir" : 'X\(//\)$' \| \
X"$as_dir" : 'X\(/\)' \| \
echo X"$as_dir" |
s/.*/./; q'`
done
test ! -n "$as_dirs" || mkdir $as_dirs
fi || { { echo "$as_me:$LINENO: error: cannot create directory
\"$ac_dir\"" >&5
echo "$as_me: error: cannot create directory \"$ac_dir\"" >&2;}
{ (exit 1); exit 1; }; }; }
ac_builddir=.
if test "$ac_dir" != .; then
ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
# A "../" for each directory in $ac_dir_suffix.
ac_top_builddir=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,../,g'`
else
ac_dir_suffix= ac_top_builddir=
fi
case $srcdir in
.) # No --srcdir option. We are building in place.
ac_srcdir=.
if test -z "$ac_top_builddir"; then
ac_top_srcdir=.
else
ac_top_srcdir=`echo $ac_top_builddir | sed 's,/$,,'`
fi ;;
[\\/]* | ?:[\\/]* ) # Absolute path.
ac_srcdir=$srcdir$ac_dir_suffix;
ac_top_srcdir=$srcdir ;;
*) # Relative path.
ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
ac_top_srcdir=$ac_top_builddir$srcdir ;;
esac
# Don't blindly perform a `cd "$ac_dir"/$ac_foo && pwd` since $ac_foo can be
# absolute.
ac_abs_builddir=`cd "$ac_dir" && cd $ac_builddir && pwd`
ac_abs_top_builddir=`cd "$ac_dir" && cd ${ac_top_builddir}. && pwd`
ac_abs_srcdir=`cd "$ac_dir" && cd $ac_srcdir && pwd`
ac_abs_top_srcdir=`cd "$ac_dir" && cd $ac_top_srcdir && pwd`
case $INSTALL in
[\\/$]* | ?:[\\/]* ) ac_INSTALL=$INSTALL ;;
*) ac_INSTALL=$ac_top_builddir$INSTALL ;;
esac
if test x"$ac_file" != x-; then
{ echo "$as_me:$LINENO: creating $ac_file" >&5
echo "$as_me: creating $ac_file" >&6;}
rm -f "$ac_file"
fi
# Let's still pretend it is `configure' which instantiates (i.e., don't
# use $as_me), people would be surprised to read:
# /* config.h. Generated by config.status. */
if test x"$ac_file" = x-; then
configure_input=
else
configure_input="$ac_file. "
fi
configure_input=$configure_input"Generated from `echo $ac_file_in |
sed 's,.*/,,'` by configure."
# First look for the input files in the build tree, otherwise in the
# src tree.
ac_file_inputs=`IFS=:
for f in $ac_file_in; do
case $f in
-) echo $tmp/stdin ;;
# Absolute (can't be DOS-style, as IFS=:)
test -f "$f" || { { echo "$as_me:$LINENO: error: cannot find
input file: $f" >&5
echo "$as_me: error: cannot find input file: $f" >&2;}
echo $f;;
*) # Relative
if test -f "$f"; then
# Build tree
echo $f
elif test -f "$srcdir/$f"; then
# Source tree
echo $srcdir/$f
else
# /dev/null tree
{ { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
fi;;
esac
done` || { (exit 1); exit 1; }
sed "/^[ ]*VPATH[ ]*=/{
s/:*\$(srcdir):*/:/;
s/:*\${srcdir}:*/:/;
s/:*@srcdir@:*/:/;
s/^\([^=]*=[ ]*\):*/\1/;
s/:*$//;
s/^[^=]*=[ ]*$//;
:t
s, at configure_input@,$configure_input,;t t
s, at srcdir@,$ac_srcdir,;t t
s, at abs_srcdir@,$ac_abs_srcdir,;t t
s, at top_srcdir@,$ac_top_srcdir,;t t
s, at abs_top_srcdir@,$ac_abs_top_srcdir,;t t
s, at builddir@,$ac_builddir,;t t
s, at abs_builddir@,$ac_abs_builddir,;t t
s, at top_builddir@,$ac_top_builddir,;t t
s, at abs_top_builddir@,$ac_abs_top_builddir,;t t
s, at INSTALL@,$ac_INSTALL,;t t
" $ac_file_inputs | (eval "$ac_sed_cmds") >$tmp/out
rm -f $tmp/stdin
mv $tmp/out $ac_file
else
cat $tmp/out
rm -f $tmp/out
fi
done
# CONFIG_HEADER section.
# These sed commands are passed to sed as "A NAME B NAME C VALUE D", where
# NAME is the cpp macro being defined and VALUE is the value it is being
given.
# ac_d sets the value in "#define NAME VALUE" lines.
ac_dA='s,^\([ ]*\)#\([ ]*define[ ][ ]*\)'
ac_dB='[ ].*$,\1#\2'
ac_dC=' '
ac_dD=',;t'
# ac_u turns "#undef NAME" without trailing blanks into "#define NAME
VALUE".
ac_uA='s,^\([ ]*\)#\([ ]*\)undef\([ ][ ]*\)'
ac_uB='$,\1#\2define\3'
ac_uC=' '
ac_uD=',;t'
for ac_file in : $CONFIG_HEADERS; do test "x$ac_file" = x: && continue
case $ac_file in
cat >$tmp/stdin
esac
test x"$ac_file" != x- && { echo "$as_me:$LINENO: creating $ac_file" >&5
# src tree.
case $f in
input file: $f" >&5
echo $f;;
*) # Relative
# Build tree
echo $f
# Source tree
echo $srcdir/$f
else
# /dev/null tree
fi;;
esac
# Remove the trailing spaces.
sed 's/[ ]*$//' $ac_file_inputs >$tmp/in
# Handle all the #define templates only if necessary.
if grep "^[ ]*#[ ]*define" $tmp/in >/dev/null; then
# If there are no defines, we may have an empty if/fi
cat >$tmp/defines.sed <<CEOF
/^[ ]*#[ ]*define/!b
t clr
: clr
${ac_dA}PACKAGE_NAME${ac_dB}PACKAGE_NAME${ac_dC}"GD"${ac_dD}
${ac_dA}PACKAGE_TARNAME${ac_dB}PACKAGE_TARNAME${ac_dC}"gd"${ac_dD}
${ac_dA}PACKAGE_VERSION${ac_dB}PACKAGE_VERSION${ac_dC}"2.0.15"${ac_dD}
${ac_dA}PACKAGE_STRING${ac_dB}PACKAGE_STRING${ac_dC}"GD 2.0.15"${ac_dD}
${ac_dA}PACKAGE_BUGREPORT${ac_dB}PACKAGE_BUGREPORT${ac_dC}"gd at boutell.com"${ac_dD}
${ac_dA}PACKAGE${ac_dB}PACKAGE${ac_dC}"gd"${ac_dD}
${ac_dA}VERSION${ac_dB}VERSION${ac_dC}"2.0.15"${ac_dD}
${ac_dA}STDC_HEADERS${ac_dB}STDC_HEADERS${ac_dC}1${ac_dD}
${ac_dA}HAVE_SYS_TYPES_H${ac_dB}HAVE_SYS_TYPES_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_SYS_STAT_H${ac_dB}HAVE_SYS_STAT_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_STDLIB_H${ac_dB}HAVE_STDLIB_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_STRING_H${ac_dB}HAVE_STRING_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_MEMORY_H${ac_dB}HAVE_MEMORY_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_STRINGS_H${ac_dB}HAVE_STRINGS_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_INTTYPES_H${ac_dB}HAVE_INTTYPES_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_STDINT_H${ac_dB}HAVE_STDINT_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_UNISTD_H${ac_dB}HAVE_UNISTD_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_ERRNO_H${ac_dB}HAVE_ERRNO_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_LIMITS_H${ac_dB}HAVE_LIMITS_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_STDDEF_H${ac_dB}HAVE_STDDEF_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_LIBZ${ac_dB}HAVE_LIBZ${ac_dC}1${ac_dD}
${ac_dA}HAVE_PNG_H${ac_dB}HAVE_PNG_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_LIBPNG${ac_dB}HAVE_LIBPNG${ac_dC}1${ac_dD}
${ac_dA}HAVE_LIBFREETYPE${ac_dB}HAVE_LIBFREETYPE${ac_dC}1${ac_dD}
${ac_dA}HAVE_FREETYPE_FREETYPE_H${ac_dB}HAVE_FREETYPE_FREETYPE_H${ac_dC}1${ac_dD}
${ac_dA}HAVE_LIBJPEG${ac_dB}HAVE_LIBJPEG${ac_dC}1${ac_dD}
CEOF
sed -f $tmp/defines.sed $tmp/in >$tmp/out
rm -f $tmp/in
mv $tmp/out $tmp/in
fi # grep
# Handle all the #undef templates
cat >$tmp/undefs.sed <<CEOF
/^[ ]*#[ ]*undef/!b
t clr
: clr
${ac_uA}PACKAGE_NAME${ac_uB}PACKAGE_NAME${ac_uC}"GD"${ac_uD}
${ac_uA}PACKAGE_TARNAME${ac_uB}PACKAGE_TARNAME${ac_uC}"gd"${ac_uD}
${ac_uA}PACKAGE_VERSION${ac_uB}PACKAGE_VERSION${ac_uC}"2.0.15"${ac_uD}
${ac_uA}PACKAGE_STRING${ac_uB}PACKAGE_STRING${ac_uC}"GD 2.0.15"${ac_uD}
${ac_uA}PACKAGE_BUGREPORT${ac_uB}PACKAGE_BUGREPORT${ac_uC}"gd at boutell.com"${ac_uD}
${ac_uA}PACKAGE${ac_uB}PACKAGE${ac_uC}"gd"${ac_uD}
${ac_uA}VERSION${ac_uB}VERSION${ac_uC}"2.0.15"${ac_uD}
${ac_uA}STDC_HEADERS${ac_uB}STDC_HEADERS${ac_uC}1${ac_uD}
${ac_uA}HAVE_SYS_TYPES_H${ac_uB}HAVE_SYS_TYPES_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_SYS_STAT_H${ac_uB}HAVE_SYS_STAT_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_STDLIB_H${ac_uB}HAVE_STDLIB_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_STRING_H${ac_uB}HAVE_STRING_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_MEMORY_H${ac_uB}HAVE_MEMORY_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_STRINGS_H${ac_uB}HAVE_STRINGS_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_INTTYPES_H${ac_uB}HAVE_INTTYPES_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_STDINT_H${ac_uB}HAVE_STDINT_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_UNISTD_H${ac_uB}HAVE_UNISTD_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_ERRNO_H${ac_uB}HAVE_ERRNO_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_LIMITS_H${ac_uB}HAVE_LIMITS_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_STDDEF_H${ac_uB}HAVE_STDDEF_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_LIBZ${ac_uB}HAVE_LIBZ${ac_uC}1${ac_uD}
${ac_uA}HAVE_PNG_H${ac_uB}HAVE_PNG_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_LIBPNG${ac_uB}HAVE_LIBPNG${ac_uC}1${ac_uD}
${ac_uA}HAVE_LIBFREETYPE${ac_uB}HAVE_LIBFREETYPE${ac_uC}1${ac_uD}
${ac_uA}HAVE_FREETYPE_FREETYPE_H${ac_uB}HAVE_FREETYPE_FREETYPE_H${ac_uC}1${ac_uD}
${ac_uA}HAVE_LIBJPEG${ac_uB}HAVE_LIBJPEG${ac_uC}1${ac_uD}
s,^[ ]*#[ ]*undef[ ][ ]*[a-zA-Z_][a-zA-Z_0-9]*,/* & */,
CEOF
sed -f $tmp/undefs.sed $tmp/in >$tmp/out
rm -f $tmp/in
mv $tmp/out $tmp/in
echo "/* Generated by configure. */" >$tmp/config.h
else
echo "/* $ac_file. Generated by configure. */" >$tmp/config.h
fi
cat $tmp/in >>$tmp/config.h
rm -f $tmp/in
if diff $ac_file $tmp/config.h >/dev/null 2>&1; then
{ echo "$as_me:$LINENO: $ac_file is unchanged" >&5
echo "$as_me: $ac_file is unchanged" >&6;}
else
echo X"$ac_file" |
s/.*/./; q'`
mkdir -p "$ac_dir"
else
as_dir="$ac_dir"
as_dirs=
echo X"$as_dir" |
s/.*/./; q'`
done
\"$ac_dir\"" >&5
rm -f $ac_file
mv $tmp/config.h $ac_file
fi
else
cat $tmp/config.h
rm -f $tmp/config.h
fi
_am_stamp_count=`expr ${_am_stamp_count-0} + 1`
echo "timestamp for $ac_file" >`(dirname $ac_file) 2>/dev/null ||
$as_expr X$ac_file : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
X$ac_file : 'X\(//\)[^/]' \| \
X$ac_file : 'X\(//\)$' \| \
X$ac_file : 'X\(/\)' \| \
echo X$ac_file |
s/.*/./; q'`/stamp-h$_am_stamp_count
done
# CONFIG_COMMANDS section.
for ac_file in : $CONFIG_COMMANDS; do test "x$ac_file" = x: && continue
ac_dest=`echo "$ac_file" | sed 's,:.*,,'`
ac_source=`echo "$ac_file" | sed 's,[^:]*:,,'`
ac_dir=`(dirname "$ac_dest") 2>/dev/null ||
$as_expr X"$ac_dest" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
X"$ac_dest" : 'X\(//\)[^/]' \| \
X"$ac_dest" : 'X\(//\)$' \| \
X"$ac_dest" : 'X\(/\)' \| \
echo X"$ac_dest" |
s/.*/./; q'`
ac_builddir=.
else
fi
case $srcdir in
ac_srcdir=.
ac_top_srcdir=.
else
fi ;;
*) # Relative path.
esac
# absolute.
{ echo "$as_me:$LINENO: executing $ac_dest commands" >&5
echo "$as_me: executing $ac_dest commands" >&6;}
case $ac_dest in
depfiles ) test x"$AMDEP_TRUE" != x"" || for mf in $CONFIG_FILES; do
# Strip MF so we end up with the name of the file.
mf=`echo "$mf" | sed -e 's/:.*$//'`
# Check whether this is an Automake generated Makefile or not.
# We used to match only the files named `Makefile.in', but
# some people rename them; so instead we look at the file content.
# Grep'ing the first line is not enough: some people post-process
# each Makefile.in and add a new line on top of each file to say so.
# So let's grep whole file.
if grep '^#.*generated by automake' $mf > /dev/null 2>&1; then
dirpart=`(dirname "$mf") 2>/dev/null ||
$as_expr X"$mf" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
X"$mf" : 'X\(//\)[^/]' \| \
X"$mf" : 'X\(//\)$' \| \
X"$mf" : 'X\(/\)' \| \
echo X"$mf" |
s/.*/./; q'`
else
continue
fi
grep '^DEP_FILES *= *[^ #]' < "$mf" > /dev/null || continue
# Extract the definition of DEP_FILES from the Makefile without
# running `make'.
DEPDIR=`sed -n -e '/^DEPDIR = / s///p' < "$mf"`
test -z "$DEPDIR" && continue
# When using ansi2knr, U may be empty or an underscore; expand it
U=`sed -n -e '/^U = / s///p' < "$mf"`
test -d "$dirpart/$DEPDIR" || mkdir "$dirpart/$DEPDIR"
# We invoke sed twice because it is the simplest approach to
# changing $(DEPDIR) to its actual value in the expansion.
for file in `sed -n -e '
/^DEP_FILES = .*\\\\$/ {
s/^DEP_FILES = //
:loop
s/\\\\$//
p
n
/\\\\$/ b loop
p
/^DEP_FILES = / s/^DEP_FILES = //p' < "$mf" | \
sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
# Make sure the directory exists.
test -f "$dirpart/$file" && continue
fdir=`(dirname "$file") 2>/dev/null ||
$as_expr X"$file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
X"$file" : 'X\(//\)[^/]' \| \
X"$file" : 'X\(//\)$' \| \
X"$file" : 'X\(/\)' \| \
echo X"$file" |
s/.*/./; q'`
mkdir -p $dirpart/$fdir
else
as_dir=$dirpart/$fdir
as_dirs=
echo X"$as_dir" |
s/.*/./; q'`
done
$dirpart/$fdir" >&5
echo "$as_me: error: cannot create directory $dirpart/$fdir" >&2;}
# echo "creating $dirpart/$file"
echo '# dummy' > "$dirpart/$file"
done
done
esac
done
{ (exit 0); exit 0; }
