queryByPoint on dynamic layer from mysql
Eric Bridger
eric at GOMOOS.ORG
Fri Feb 17 16:46:37 EST 2006
I don't use PHP mapscript (Perl mapscript) but I believe you would need
to use the shape index to retrieve the feature data from mysql yourself.
In perl mapscript I had no trouble setting shape->{index} to any numeric
value. They did not have to be sequential. So I would use some unique
numeric key from my database table. Alternatively you could create a
lookup array where your mysql keys are stored.
Eric
On Fri, 2006-02-17 at 13:58, Doug Williams wrote:
> Hi,
> Trying to query points that I have added to my map with php_mapscript from a
> mysql table.
> I've bumbled through the "set index" problem in older versions,
> have installed MapServer 4.8.1,
> and now seem to be able to get records from my query, but...
> while the points and labels show up on the map properly,
> indicating that the layer of points is being created and the lat/lon and label
> values are associated properly,...
> when I process the records obtained from my queryByPoint,
> using getShape to get at the details,
> There is no data in the shape object's members for the dynamic layer, although
> the result objects from the point query do have the correct index values that
> I programmatically set (incrementing from zero by 1 ... i tried incrementing
> by five to see if index values needed to be 'just so', and that broke the
> point query - yes, i believe they need to increment by one from zero).
> Querying layers (from standard shape files added to the map from a mapfile)
> with the same code works as expected. I can get a shapes member values with
> either values() or getValue() ... works the same both ways.
> It was not possible to query dynamically added points in phpmapscript in the
> old version I last installed (4.4) because the index for the shapes was
> readonly and incorrectly set to -1. Now I can set the index values and the
> queryByPoint does grab the point, but the result record seems to have no data.
> I must be doing something wrong.
> Any help is greatly appreciated!
> Here's the bit of code where I can't get the details for the dynamic layer,
> though the code works for the mapfile layers.
> This code was copied from the list serve and modified slightly
> for ($iRes=0; $iRes < $numResults; $iRes++)
> $oRes = $oLayer->getResult($iRes);
> //echo "<script>window.alert('oRes tile index: " . $oRes->tileindex . " oRes
> shape index: " . $oRes->shapeindex . "')</script>";
> // the shape index values I 'set' when adding the points (in prior code, shown
> below) are correct, tileindex values were -1
> $oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
> printf("<TR>\n");
> //printf("<script>window.alert(' bounds(%f, %f)-(%f, %f)')</script>",
> // $oShape->bounds->minx, $oShape->bounds->miny,
> // $oShape->bounds->maxx, $oShape->bounds->maxy);
> // bounds values are good for all layer records EXCEPT dynamic, for which they
> are all 0 (zero)
> for($iField=0; $iField < sizeof($selFields); $iField++)
> // $tempval = $oShape->getValue($oLayer, $selFields[$iField]); // both these
> methods give the same results
> $tempval = $oShape->values[$selFields[$iField]]; // both these methods give
> the same results
> // in both cases I get the field name properly from $selFields
> // but not the value from the shape object
> // again, the problem only occurs for the dynamic layer
> // data is properly read for the other layers
> if ($iLayer == "points") { // points is the dynamic layer - this is just for
> debugging as with the other alerts
> echo "<script>window.alert('$iLayer : $selFields[$iField] : $tempval
> :')</script>";
> printf("<TD BGCOLOR=#FFFFFF>");
> printf("%s", $tempval);
> printf("</TD>");
> printf("</TR>\n"); // yes, i know they say not to use tables anymore
> $oShape->free();
> $numResultsTotal++;
> here is the code where I create the dynamic layer:
> // this function came from the list server, although I added input variables
> for label ($labeltext) and index ($pointnumber)
> function add_point_to_layer($layer, $longitude, $latitude, $labeltext,
> $point_number) {
> // create and initialize new point object
> $point = ms_newPointObj();
> $point->setXY($longitude, $latitude);
> // create and initialize new line object
> $line = ms_newLineObj();
> $line->add($point);
> // create and initialize new shape object
> $shape = ms_newShapeObj(MS_SHAPE_POINT);
> $shape->add($line);
> //echo "<script>window.alert('label text: " . $labeltext . "')</script>";
> $shape->set('text', $labeltext);
> $shape->set('index', $point_number);
> // add our shape
> $layer->addFeature($shape);
> if ($pointshow) {
> if (!$orderby) $orderby = "id";
> // echo $orderby . "<br>";
> $query = "select * from peop order by $orderby";
> $points = mysql_query($query);
> if ($points) {
> $num_points = mysql_num_rows($points);
> //echo "$num_points";
> if ($num_points > 0) { // this code was copied from the list serve and
> modified slightly
> $ptlayer = ms_newLayerObj($map);
> $ptlayer->set("name", "points");
> $ptlayer->set("type", MS_LAYER_POINT);
> //$ptlayer->setProjection("init=epsg:4326");
> $ptlayer->set("status", MS_ON);
> $ptlayer->setMetaData("DESCRIPTION", "Points");
> $ptlayer->setMetaData("RESULT_FIELDS", "text index"); // these are
> the shape members that I wish to read in the query
> $ptlayer->set("template", "points_template.html");
> $ptclass = ms_newClassObj($ptlayer);
> $ptclass->set("status", MS_ON);
> $ptclass->set("name", "Points");
> $ptclass->label->set("type", MS_TRUETYPE);
> $ptclass->label->set("font", 'times');
> $ptclass->label->color->setRGB( 200,100,200);
> $ptclass->label->outlinecolor->setRGB(255, 255, 255);
> $ptclass->label->set("size", 11);
> $ptclass->label->set("position", 1);
> $ptstyle = ms_newStyleObj($ptclass);
> $ptstyle->set("symbol", $map->getsymbolbyname( 'circle'));
> $ptstyle->set("size", 8);
> $ptstyle->color->setRGB( 200,100,200);
> $ptstyle->outlinecolor->setRGB(255, 255, 255);
> for ($i=0; $i < $num_points; $i++) {
> $row = mysql_fetch_array($points);
> //echo "<script>window.alert('outer- label text: " . $row["username"] .
> "')</script>";
> $indexforshape = $i;
> $labeltxt = $row["username"];
> add_point_to_layer($ptlayer, $row["lon"], $row["lat"], $labeltxt,
> $indexforshape);
> } else {
> //echo "$num_points points in database.<br><br>"; // should be zero
> } else {
> //echo "Query error.";
