Raster Problem in ms4w
    Pericles S. Nacionales
    naci0002 at UMN.EDU
    Sat Feb 18 08:08:17 PST 2006
Have you tried using the absolute path to your raster image?
e. g.: DATA "/ms4w/apps/sample1/data/nitelti020l.tif"
If that also doesn't work, check your permissions and make sure that all users
can read it.
Good luck!
-Perry
On Saturday 18 February 2006 02:27, baarFan (sent by Nabble.com) wrote:
> Hi everybody,
> I am dealing with mapserver nearly 2 months and my studies was all on linux
> till last 1 week. In FGS package I was able to load raster layers to my
> map. But in ms4w with the same map file I could not load the raster layer.
> But vector layer is still ok. I have updated all the links for windows. Do
> you have any  idea why this situation occurs? An example map file is below.
> MAP
>     NAME USA3
>     STATUS ON
>     IMAGETYPE PNG
>     SIZE 800 500
>     SHAPEPATH "../data/"
>     EXTENT -6086744.000 -2784127 4278894 4485901
>     UNITS METERS
>     PROJECTION "proj=laea" "lat_0=45" "lon_0=-100" "ellps=GRS80"
> "datum=NAD83" END
> 		WEB
> 			IMAGEPATH "C:/ms4w/Apache/htdocs/tmp/"
> 			IMAGEURL "/tmp/"
> 		END
> 		LAYER
> 			NAME "US state boundaries"
> 			TYPE POLYGON
> 			STATUS ON
> 			DATA "statesp020"
> 			PROJECTION
> 				"proj=latlong"
> 				"ellps=GRS80"
> 				"datum=NAD83"
> 			END
> 			CLASS
> 				NAME "US states"
> 				OUTLINECOLOR 50 50 50
> 				SYMBOL 0
> 			END
> 		END
> 		LAYER
> 			NAME "Nighttime lights"
> 			TYPE RASTER
> 			STATUS ON
> 			DATA "nitelti020l.tif"
> 		END
> END
> tfw file is
> 769.4780
> 0.000000
> 0.000000
> -769.4780
> -6086744.0000
> 4485901.0000
> and my simple phpscript is here..
>  dl('php_mapscript_46.dll');
>  $map_path="C:\ms4w\apps\sample1\htdocs\\";
>  $map_file="europe.map";
>  $map = ms_newMapObj($map_path.$map_file);
>  $image=$map->draw();
>  $image_url=$image->saveWebImage();
>   echo $image_url
>  <INPUT TYPE=IMAGE NAME="mapa" SRC="<?php echo $image_url?>" border="1">
> thanx in advance...
> Burak Oguz
> http://www.nabble.com/Raster-Problem-in-ms4w-t1145396.html#a3003035 Sent
> from the Mapserver - User forum at Nabble.com.
Conservation Biology Program
University of Minnesota
e-mail: naci0002 at umn.edu
More information about the MapServer-users
