Raster Layer Doubt {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Sun Feb 19 16:13:57 EST 2006
Some idea
Add STATUS DEFAULT or STATUS ON, I am not sure what is the default.
Is it a GeoTif? Do you have georeference for your raster file?
Try gdalinfo to get the answer.
If it's not a GeoTif than you must have an india.tfw in the same
directory.
What about projection? Are your shapes in the same projection?
You should check the coordinates of the georeference.
Have you read Raster-Howto on Mapserver web page?
Bye,
Zoltan
On Sun, 19 Feb 2006, Apeksha Bhambhani wrote:
> Hi all ,
> We have developed a web-mapping application . Our mapping application uses Mapserver , Php/Mapscript as the scripitng language and MySql as the database.And this application accepts user clicks and allows the user to edit the map : adding points, etc.
> Now for this map , we require a base map - which is a raster layer .
> We have tried editing the mapfile as follows:
> LAYER
> NAME "base"
> TYPE raster
> DATA "india.tif"
> END
> But this is of no help. The tiff file resides in the shapefiles directory .
> We want to include this raster image as our base map. Is this the right way or is there any other way?
> Could someone please help us.
> Thanks
> Apeksha
> Yahoo! Mail
> Use Photomail to share photos without annoying attachments.
