problem with ogr ovf connection
Janeks Kamerovskis
janeks.kamerovskis at SILVA.LV
Tue Feb 21 15:40:24 EST 2006
Thanks Frank,
Escaping < sign works!
But what you mean by asking about where statement?
I already using them in that ogr connection. And I have plans to implement
some additional filtering by passing user suplied arguments. Something like
puting in connection string where part '%district%', where district comes
from ...varname=123&district=456&...
Janeks
> Could you provide the OVF file in question? A couple possibilities come
> to mind:
> o The < sign may need to be escaped in the XML OVF file (as <).
> o If this is the contents of a SrcSQL you will need a WHERE statement
> won't
> you?
> Perhaps I am misunderstanding what you mean when you talk about adding
> the above field.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
