Postgis and EXPRESSION
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Thu Feb 23 02:32:07 EST 2006
Hmm, tried this too now. Not that it made a difference, but it gave
me an idea. It sounds really stupid, but although I used "character
varying" as the field definition I had the impression that something
was wrong within the fields. So, I found out that there were empty
spaces behind the field values. I have no idea how they got there.....
Relieved, but ashamed, it refreshed the views... and.... still, it
did not work...
So, meanwhile I have this definition:
LAYER
NAME bg_shape
CONNECTIONTYPE postgis
CONNECTION 'user=xxx password=xxx dbname=xxx'
TYPE POLYGON
DATA 'the_geom FROM countries_regions_view USING UNIQUE id USING
srid=-1'
CLASSITEM 'reg_name'
CLASS
NAME ''
EXPRESSION ([reg_name] ne 'Africa')
OUTLINECOLOR 230 230 230
COLOR 230 230 230
END
END
and attached is a screenshot of the view.
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060223/1fb25040/screenshot62.png
> Stefan,
> I am not sure if this could work for you, but you could try
> creating a view or a function (if parameters are needed) and then
> call that from MSS. I've used that to avoid constructs that MSS
> didn't like, or to do other behind-the-scenes processing.
> Plus diagnosing the postgres sql errors is sometimes easier than
> figuring out what MSS is doing, depending on how it is configured.
> Greg Williamson
> DBA
> GlobeXplorer LLC
> -----Original Message-----
> From: UMN MapServer Users List on behalf of Stefan Schwarzer
> Sent: Wed 2/22/2006 10:55 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Cc:
> Subject: Re: [UMN_MAPSERVER-USERS] Postgis and EXPRESSION
> Thanks for the suggestions.
> Unfortunately neither one of them worked.
> 1) The CLASSITEM seems not to be the problem. At least when I took it
> away it still didn't use the the EXPRESSION.
> 2) For the NATURAL JOIN I get an error message. (Postgresql reports
> the error as 'ERROR: syntax error at or near "ON" at character 251
> '). But the LEFT JOIN seems to work and when I run the query directly
> in the database the result looks correct.
> I tried to play a bit around, but without success...
> Just to be sure that I understand it correctly: the EXPRESSION
> parameter references to the alias in the SELECT statement, no? So if
> I have
> regions_view.name AS name
> then my
> EXPRESSION ([name] ne 'Africa')
> is based on the alias...
> Gush, I am really stuck there...
> Stef
> On Feb 22, 2006, at 10:14 PM, Clint Johnson wrote:
>> I believe your script is failing at the DATA clause -- or because
>> there exists no data within your tables that is join-able.
>> *[Malformed DATA clause]*
>> I've run into a similar problem myself before.
>> I am pretty sure your problem is with your DATA statement. In fact
>> it may be throwing an exception that you haven't been able to see
>> (rather than ignoring the expression).
>> See the advanced-usage at: http://postgis.refractions.net/docs/
>> ch04.html#id2789268
>> Note that the SQL used within the DATA tag is "pseudo-SQL"
>> Do not use the WHERE clause to perform your join; instead, use the
>> NATURAL JOIN operator. Instead, only use the WHERE clause to
>> filter upon items as you would with the FILTER tag (such as
>> regions_view.name = 'foo'). I believe the FILTER and WHERE clauses
>> to be coupled (which further complicates matters when doing a
>> complex join in your DATA clause).
>> Therefore, try this and let me know if it works:
>> DATA "the_geom FROM (SELECT countries.the_geom AS the_geom,
>> regions_view.name AS name, countries.oid AS oid FROM countries
>> NATURAL JOIN regions_view ON countries.geo_region =
>> regions_view.id) AS foo using unique oid using srid=-1"
>> *[Nothing to join]*
>> Perhaps there is nothing to join -- in that case try using LEFT
>> JOIN instead of the NATURAL JOIN
>> Clint
>> Stefan Schwarzer wrote:
>>> Hi,
>>> I migrated from mysql to postgres/postgis and update now all my
>>> map-queries. But I have a problem getting it working. I wonder if
>>> this is a major problem or some minor issue. The doc says :
>>> *"**Logical expressions allow you to build fairly complex tests
>>> based on one or more attributes and therefore are only available
>>> with shapefiles"*
>>> So, i would almost presume that using EXPRESSIONS is not possible
>>> via postgis. But I can't imagine that this is true... In the
>>> moment it runs the query but with no result - meaning that it
>>> "ignores" the epression. I couldn't find anything similar in the
>>> archives either...
>>> LAYER
>>> NAME bg_shape
>>> TYPE POLYGON
>>> DATA 'the_geom FROM (SELECT countries.the_geom AS the_geom,
>>> regions_view.name AS name, countries.oid AS oid FROM countries,
>>> regions_view WHERE countries.geo_region = regions_view.id) AS foo
>>> USING UNIQUE oid USING srid=-1'
>>> CLASSITEM 'name'
>>> CLASS
>>> NAME '' EXPRESSION ([name] ne 'Africa')
>>> COLOR 230 230 230
>>> END
>>> END # LAYER
>>> Thanks for any help!
>>> Stef
>> Clint Johnson
>> Refractions Research Inc.
>> Cjohnson at refractions.net
> !DSPAM:43fd5c91219451348188260!
