UMN Mapserver on mobile devices
Puneet Kishor punkish at EIDESIS.ORG
Thu Feb 23 11:30:01 PST 2006
Rainer Spittel wrote:
> Hi there,
>   It just came in my mind: I wonder if is might be possible to setup a UMN
> Mapserver environment on a mobile/handheld device (cellphone, PocketPC
> etc.)? So the MapServer runs on the PocketPC including core geospatial
> datasets (contours etc.) and accesses a WMS through the internet connection.
> May there is a "ms4mob" ? ;-)
>   Does anyone has experience with that? Is there a documentation available?
no answer here for your specific question, but -- why would you want to
run MapServer on a handheld when you could use the browser on your
handheld to access MapServer installed on a real computer? I mean, that
is the whole point of running a server, so remote and mobile users (and
not just those holding mobile devices) can access the data. All you
would have to do is create a small-screen optimized version of your
site; fairly easy to do if you are using a scripting environment with
some kind of templating system.
More information about the MapServer-users mailing list
