help can ´t display a point layer
Luis Trevi ño
ltrevino at GPOBSI.COM.MX
Thu Feb 23 12:13:48 PST 2006
I´m using mapserver 4.4.1 and I need to display a point layer that get´s
the data from a postgis table and it´s geographic values are in utm. (this
data comes from a GPS with utm values)
The other layer get their data also from postgis tables, but their
geographic values are in lat/long, (proj=longlat, ellps=GRS80
datum=WGS84), so I can display with no problem de lat/long layers but
can´t display the utm layer.
this is part of my map file:
MAP
NAME Pg5-
STATUS ON
EXTENT -99.181 19.3411 -99.1493 19.3612
SIZE 960 600
SYMBOLSET 'symbols.sym'
FONTSET 'fonts.txt'
IMAGETYPE GIF
IMAGECOLOR 255 255 255
UNITS dd
WEB
IMAGEPATH '/var/www/tmp/'
IMAGEURL '/tmp/'
TEMPLATE Gistemplate.html
#MINSCALE
#MAXSCALE
END
PROJECTION
"proj=longlat"
"ellps=GRS80"
"datum=WGS84"
"no_defs"
END
#this is the layer that I can't display
LAYER #gis
NAME gis
STATUS ON
TYPE POINT
UNITS METERS
CONNECTION "user=XX password=XXX dbname=XXX host=XXX.XXX.XXX.XX
port=5432"
CONNECTIONTYPE postgis
DATA "posicion from loca as foo using unique cmpoid using srid=-1"
PROJECTION
"proj=utm"
"ellps=WGS84"
END
CLASS
COLOR 255 0 0 #rojo
SYMBOL 7
SIZE 7
END
END
LAYER
NAME cuadras
TYPE POLYGON
STATUS ON
CONNECTION "user=XX password=XX dbname=XX host=XXX.XXX.XXX.XX port=5432"
DATA "the_geom from cuadras as foo using unique gid using srid=-1"
CLASS
COLOR 170 115 90
OUTLINECOLOR 15 155 200
END
END
don´t know what I'm doing wrong. Please Help me
regards,
Luis
More information about the MapServer-users
