mapscript error
Aaron Koning
aaronkoning at GMAIL.COM
Fri Feb 24 01:39:59 EST 2006
Did you compile mapserver with libraries found in /usr/local/lib/? If so the
php_mapscript_40.so might be finding/using the default libraries in
/usr/lib/ or /lib/, which might cause this error. Are you loading
php_mapscript_40.so with the PHP binary compiled from the PHP source you
referenced in the mapserver build? Compiling with one version and loading
with another may cause the error.
I'm sure I had this problem before too...
Aaron
On 2/23/06, SUBSCRIBE MAPSERVER-USERS Anonymous <tano01 at libero.it> wrote:
> I'm sorry Aaron...all libraries are founded! Any other ideas??
> Gaetano
> libmap.so.4.6.0-beta2 => /usr/lib/libmap.so.4.6.0-beta2
> (0xb7514000)
> libcurl.so.3 => /usr/lib/libcurl.so.3 (0xb741f000)
> libdl.so.2 => /lib/libdl.so.2 (0xb741c000)
> libz.so.1 => /usr/lib/libz.so.1 (0xb740e000)
> libpq.so.3 => /usr/lib/libpq.so.3 (0xb73f8000)
> libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0xb73db000)
> libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0xb7377000)
> libpng.so.3 => /usr/lib/libpng.so.3 (0xb734d000)
> libgdal.so.1 => /usr/lib/libgdal.so.1 (0xb6efd000)
> libproj.so.0 => /usr/lib/libproj.so.0 (0xb6ecb000)
> libgd.so.2 => /usr/lib/libgd.so.2 (0xb6e7f000)
> libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0xb6dcc000)
> libm.so.6 => /lib/tls/libm.so.6 (0xb6da9000)
> libc.so.6 => /lib/tls/libc.so.6 (0xb6c72000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb6c69000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
> libcrypt.so.1 => /lib/libcrypt.so.1 (0xb6c3c000)
> libresolv.so.2 => /lib/libresolv.so.2 (0xb6c2a000)
> libnsl.so.1 => /lib/libnsl.so.1 (0xb6c14000)
> libodbc.so.1 => /usr/lib/libodbc.so.1 (0xb6bba000)
> libxerces-c.so.26 => /usr/lib/libxerces-c.so.26 (0xb6886000)
> libpthread.so.0 => /lib/tls/libpthread.so.0 (0xb6876000)
> libungif.so.4 => /usr/lib/libungif.so.4 (0xb686f000)
> libgeotiff.so => /usr/lib/libgeotiff.so (0xb684e000)
> libtiff.so.3 => /usr/lib/libtiff.so.3 (0xb6802000)
> libnetcdf.so => /usr/lib/libnetcdf.so (0xb67e1000)
> libnss_files.so.2 => /lib/libnss_files.so.2 (0xb67d5000)
> libnss_dns.so.2 => /lib/libnss_dns.so.2 (0xb67d0000)
> libpng12.so.0 => /usr/lib/libpng12.so.0 (0xb67a6000)
> libSM.so.6 => /usr/X11R6/lib/libSM.so.6 (0xb679d000)
> libICE.so.6 => /usr/X11R6/lib/libICE.so.6 (0xb6786000)
> libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0xb66a7000)
| Aaron Koning
| Information Technologist
| Prince George, BC, Canada.
| http://datashare.gis.unbc.ca/fist/
| http://datashare.gis.unbc.ca/gctp-js/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060223/c2e35f53/attachment.html
