Web Map Context interoperability problems
Daniel Morissette
dmorissette at MAPGEARS.COM
Tue Feb 28 15:07:11 EST 2006
Hi Bart,
Could you please file a bug and Julien will have a look and provide more
precise answers?
Quick comments about the issues that you raised:
About the EPSG code not being recognized, we've used 4326 before and I
don't thing the pszValue+5 implies that the EPSG code needs to be 5
digits, I think it's there to skip the "EPSG:" prefix. It has to be
something else, we'll need to check further with this
About #1: you're right that this is missing
About #2: MapServer 4.9 should spit out "OGC:WMS" for v1.1.0 contexts,
and "WMS" for 1.0.0 ... I didn't double-check the specs, but I think
this is the correct behavior.
Daniel
Bart van den Eijnden wrote:
> Hi list,
> I am trying to use a WMC document generated by Ionic in Mapserver, but
> cannot get it to work (no layers in map object). The Ionic context
> validates in Oxygen.
> First problem, Ionic does not use a XML header for the context, so
> Mapserver comes back with:
> PHP Warning: [MapServer Error]: msLoadMapContext(): Invalid XML file
> (/data/geoservices/apps/geoservices/htdocs/ionic.cml)
> in /data/geoservices/apps/geoservices/htdocs/wmc_ionic.php on line 5
> So I added the XML header by hand. Then the following problem occurs:
> PHP Warning: [MapServer Error]: msLoadMapContext(): Unable to set units
> for projection ''
> Could it be that the Mapserver code assumes a 5 letter SRS EPSG code? If I
> use e.g. 28992 it runs fine.
> sprintf(pszProj, "init=epsg:%s", pszValue+5);
> I have seen a few other potential problems in the Mapserver code:
> 1) the parsing code for queryable etc. assumes to get a 0 or 1, whereas
> true or false are also valid values for xs:boolean
> 2) when outputting a WMC, Mapserver uses WMS for the value of the service
> attribute of Server, whereas the OGC example (on schemas.opengis.net) as
> well as Ionic use OGC:WMS
> <Server service="OGC:WMS"
> I have attached the context if somebody is interested to try this out.
> Best regards,
> Bart
> <ViewContext xmlns:xlink="http://www.w3.org/1999/xlink" xsi:schemaLocation="http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd" xmlns="http://www.opengis.net/context" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" id="none" version="1.0.0">
> <General>
> <Window width="600" height="300"></Window>
> <BoundingBox SRS="EPSG:4326" miny="28.200000000000017" maxy="58.80000000000001" maxx="41.39999999999999" minx="-19.799999999999994"></BoundingBox>
> <Title>World view</Title>
> <Abstract>Example Context</Abstract>
> </General>
> <LayerList>
> <Layer hidden="0" queryable="false">
> <Server service="OGC:WMS" title="WORLD" version="1.1.1">
> <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://webservices.ionicsoft.com/worldData/map/WORLD" xlink:type="simple"></OnlineResource>
> </Server>
> <Name>WORLD</Name>
> <Title>WORLD</Title>
> <Abstract></Abstract>
> <StyleList>
> <Style current="1">
> <Name>default</Name>
> <Title>default</Title>
> </Style>
> </StyleList>
> </Layer>
> </LayerList>
> </ViewContext>
Daniel Morissette
http://www.mapgears.com/
