Annotation layer not redisplaying on zoom-in
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Tue Jan 3 14:34:42 PST 2006
hmm. To rule out any maplab issues, you could use the shp2img.exe in
\ms4w\tools\mapserv-utils\, which will create your map image:
and test your mapfile with different extents...
jeff
ANDERSON, WALTER wrote:
> I just gave that a try with no change noted. I also changed the color
> at the same time to verify that it was working with the revised map file.
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
More information about the MapServer-users
