Keysize for raster legend
Jørn Vegard Røsnes
jorn at SPACETEC.NO
Wed Jan 4 10:21:10 EST 2006
Hi all,
I'm using mapserver to visualize satellite derived products on a raster
format (tif) with a raster legend embedded into the image.
Attached is a screen shot visualizing my problem.
The screenshot shows a sea surface temperature layer but I'm not getting the
color bar legend that I expected.
The strange thing is that if I don't specify the LEGEND -> KEYSIZE tag
but using the default
values "20 10", the color legend looks ok but is too small to read.
Attached is also the colorbar jpg that should be embedded as a legend.
I am using the KEYIMAGE tag in the map file to include the legend file.
Below is an extract of the map file.
Another question related:
LEGEND -> KEYSIZE gives a general size of the legend.
Is it possible specify the size of a layer's legend?
It is often necessary/nicer to have different size of legends of different
layers.
cheers
Joern Vegard Roesnes
MAP
NAME DEMO
STATUS ON
SIZE 600 600
UNITS METERS
SHAPEPATH "data"
FONTSET "fonts.txt"
EXTENT -72493.34 5453045.5 100000 8922059.5
IMAGECOLOR 255 255 255
IMAGETYPE png
PROJECTION
"init=epsg:32633"
END
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
IMAGEPATH "/usr/local/apache/htdocs/tmp/"
IMAGEURL "/tmp/"
END
LEGEND
STATUS EMBED
POSITION UR
KEYSIZE 150 150
END
LAYER
NAME "msgSST"
DATA "SST.tif"
TYPE RASTER
STATUS default
DEBUG ON
OFFSITE 255 255 255
PROJECTION
"proj=stere"
"lat_0=40"
"lon_0=0"
END
CLASS
NAME ""
KEYIMAGE 'data/msgSSTcolor.png'
END
END
END
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060104/1631f48a/msgSSTcolor.png
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060104/1631f48a/applet_legen.jpg
