Oracle and SELECTs with OGR . .
Bob Basques
bob.basques at CI.STPAUL.MN.US
Wed Jan 4 15:49:01 EST 2006
Frank Warmerdam wrote:
>>What we want to do as the "outer select":
>>select * from sewer_permits1 where ogr_fid in (select max(ogr_fid) from
>>sewer_permits1 group by id);
>>We can't seem to get this to be used AFTER the Spatial Select occurs
>>from the MapServer Request. It's rather slow if it's used before the
>>MapServer Spatial Filter, so we need the Spatial aspects to run first,
>>then run this statement on the output from the MapServer Spatial
>>operation instead of the whole DB.
> Bob,
>I don't think it is possible to use an accelerated
>spatial query with a SELECT statement (that is using
>the ExecuteSQL() entry in the driver) in the OGR OCI
>driver. If you aren't in a position to use the built-in
>Oracle support in Mapserver, you may have to start
>changing code in non-trivial ways.
What about passing the IMGEXT into the MAPFILE from the CGI request
(can't that be done just like a template) and we do the whole thing in
the ExecuteSQL in the MapFile.
something like:
where ogr_fid
from sewer_permits1
where MDSYS.SDO_RELATE(Table0.GEOMETRY,
MDSYS.SDO_GEOMETRY (3003,
41072,
NULL,
MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),
MDSYS.SDO_ORDINATE_ARRAY([minx],[miny],0,
[minx],[maxy],0,
[maxx],[maxy],0,
[maxx],[miny],0,
[minx],[miny],0)
'MASK=ANYINTERACT QUERYTYPE=WINDOW') = 'TRUE'
group by id);
Will this work ok you think, or can we even pass the IMGEXT into the SQL
like this?
bobb
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.c=
>om
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
