Creating a designated graphics file
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Wed Jan 4 16:03:10 EST 2006
Do you need this functionality to be available from the web? Then as Tom
said you'll probably need Mapscript.
If you don't need it from the web, you could use shp2img and use > to
output it to a file. Ofcourse you can write your files to a
web-accessible directory.
shp2img -m mymap.map > c:\temp\out.png
Best regards,
Bart
Chip Taylor wrote:
>Is there a way to use MapServer CGI to output a graphics file (GIF or JPG)
>to a designated location with a designated name on a Windows/IIS server?
>For example, I'd like to be able to call mapserver.exe and tell it to name
>the file "thismap.jpg" and create it in directory c:\wwwroot\projects\maps\
>Chip Taylor
>Prepared Response, Inc
OSGIS, Open Source GIS
http://www.osgis.nl
