Annotation layer not redisplaying on zoom-in
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Wed Jan 4 18:47:50 EST 2006
It seems the problem was that the point data for the "Route Labels"
layer is actually a measured shapefile, and the phpmapscript build in
MS4W was not compiled for this support (a specific flag must be set for
measured shapefiles). Not exactly an easy one to debug ha.
jeff
ANDERSON, WALTER wrote:
> Jeff,
> Here are the results.
> This command:
> resulted in this <a
> href="http://files.walteranderson.us/outgoing/test1.gif">image
> (http://files.walteranderson.us/outgoing/test1.gif)</a>
> and this command:
> shp2img -m d:\ms4w\apps\hba\data\hba.map -o \test2.gif -e 2950000
> 9980000 3255000 10205000
> resulted in this <a
> href="http://files.walteranderson.us/outgoing/test2.gif">image
> (http://files.walteranderson.us/outgoing/test2.gif)</a>
> McKENNA, JEFF wrote:
>>hmm. To rule out any maplab issues, you could use the shp2img.exe in
>>\ms4w\tools\mapserv-utils\, which will create your map image:
>>and test your mapfile with different extents...
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
