Georeferencing question
Gambin Dejan Dejan.Gambin at PULA.HR
Thu Jan 5 00:05:00 PST 2006
Thanks Frank,
I have tried using four corner points, just for testing (I know I have
to find more gcp-s):
gdal_translate -gcp 0 0 5409006.4226 4970689.5864 -gcp 0 5931
5409006.4226 4970064.7150 -gcp 7590 0 5409806.0064 4970689.5864 -gcp
7590 5931 5409806.0064 4970064.7150 025-k.jpg 025-k-translated.tif
gdalinfo on 025-k-translated says:
Then I tried:
gdalwarp -tps -co "TFW=YES" 025-k-translated.tif 025-k-warped.tif
but I get
"Creating output file that is 1417111232P x 0L.
ERROR 1: Attempt to create 1417111232x0x3 TIFF file, but width, height
and bands must be positive.
Obviously I am doing something wrong, I am not very familiar with the
transformation algorithms (although I would very like to know where can
I read something about this), I can only run gdawarp with "order 1".
I would appreciate if you can tell me what is wrong and do you maybe
have suggestions/advices on how to proprely choose gcps. transformation
algorithms, resampling methods, etc. Maybe I can read it somewhere so I
can really learn :-))
thanks
dejan
> -----Original Message-----
> From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On
> Behalf Of Frank Warmerdam
> Sent: Wednesday, January 04, 2006 5:22 PM
> To: Gambin Dejan
> Cc: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] Georeferencing question
> On 1/4/06, Gambin Dejan <Dejan.Gambin at pula.hr> wrote:
> > Hello,
> > I know it probably belong to gdal list but I'll give it a try here..
> > I am trying to georeference my scanned paper maps. I have
> tried using
> > QGIS Georeferencer plugin, it works ok for linear
> transformation but
> > the resulting georeferenced raster map does not fit vrey well,
> > probably because of deformations etc. I have tried using Helmert
> > transformation but unfortunatelly QGIS crashes (running on Windows).
> > So I tried using gdal_translate and gdalwarp. I took the corner
> > coordinates (only UpperLeft and BottomRight for testing) and run
> > "gdal_translate -gcp 0 0 5409006.4226 4970689.5864 -gcp 7590 5931
> > 5409806.0064 4970064.7150 025-k.jpg 025-k-translated.jpg -of JPEG".
> > But setting output format to JPEG results in unchanged output image.
> > I suppose it is normal and gdal_translate cannot create gc
> points in
> > this way? Do I have to use default TIFF output format?
> Gambin,
> Only a few formats support GCPs.  You would need to write
> output to a format like TIFF or VRT.
> > What to do next with gdalwarp? What type of transform and
> resampling
> > to use?
> If you succeed in attaching a fair number of GCPs (at least
> more than the 3 defining an affine transform) then you could
> try the -tps switch to use thin plate splines instead of
> simple polynomials. It may give better results.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
More information about the MapServer-users mailing list
