no legendgraphic for class with (colored) TEXT as a symbol
Huub Fleuren hfl at HOME.NL
Fri Jan 6 07:01:21 PST 2006
Bart,
thanks, the following is the correct way to do it
adding a symbol
SYMBOL
 NAME B
 TYPE TRUETYPE
 FONT arial_bold
 FILLED true
 ANTIALIAS true
 CHARACTER 'B'
END
and changing
 CLASS
   EXPRESSION ([PROJECTSOORT] = 200)
   NAME "Bouwlocatie"
   STYLE
       SYMBOL 'B'
       COLOR 255 100 0
       SIZE 14
   END
 END
Regards, Huub (geodan)
Bart van den Eijnden (OSGIS) wrote:
> Huub,
> I don't think text is used for legends.
> How about defining a TRUETYPE symbol with the same font (arial_bold)
> and specifying the character (B) you want? That should work.
> Best regards,
> Bart
> Huub Fleuren wrote:
>> Hi list,
>> I have a points layer that will show as big 14 point orange
>> arial_bold B's if its PROJECTSOORT = 200
>> This goes allright
>> The problem is that the legendgraphic request doesn't show this B,
>> nor its color, nothing in fact.
>> If I insert a SYMBOL (e.g. a big point) the legendgraphic gives me
>> the symbol but the point will cover the B when showing the layer
>> Could it be that the LABEL keyword interferes with the instruction
>> for the label in the legend
>> CLASS
>>   TEXT "B"
>>   NAME "Bouwlocatie"
>>   LABEL
>>     SIZE 14
>>     POSITION CC
>>     COLOR 255 100 0
>>     TYPE TRUETYPE
>>     FONT arial_bold
>>     ANTIALIAS false
>>     BUFFER 0
>>     FORCE true
>>   END
>> END
>> Huub
More information about the MapServer-users mailing list
