Map not rendering
Hester Jane Viola
H.Viola at BOM.GOV.AU
Sun Jan 8 19:17:38 PST 2006
The problem is easily solved.
Your request does actually work, in that it returns an image, but will not render any layers unless you set them to be drawn by default.
using : STATUS DEFAULT
Have a look at the following:
Copyright layer only (which has STATUS DEFAULT)
http://www4.bom.gov.au/cgi-bin/mapserver/mapserv?map=%2Fweb%2Fhtdocs%2Fmapserver%2Fweather.map&mode=map
and
http://www4.bom.gov.au/cgi-bin/mapserver/mapserv?map=/web/htdocs/mapserver/weather.map&version=1.1.1&service=WMS&request=GetMap&layers=copyright&SRS=EPSG:4283&bbox=111,-48.3,158,-4.2&transparent=true
versus:
Copyright and coast (though copyright is not required in either request, but it is still returned)
http://www4.bom.gov.au/cgi-bin/mapserver/mapserv?map=/web/htdocs/mapserver/weather.map&version=1.1.1&service=WMS&request=GetMap&layers=coast&SRS=EPSG:4283&bbox=111,-48.3,158,-4.2&transparent=true
and
http://www4.bom.gov.au/cgi-bin/mapserver/mapserv?map=%2Fweb%2Fhtdocs%2Fmapserver%2Fweather.map&mode=map&layer=coast
Hope that makes sense
Cheers
Hester
http://www4.bom.gov.au/mapserver
Regards
Hester VIOLA
IT Officer, Data Management
Bureau of Meteorology
700 Collins St, Melbourne
Australia, 3008
Email. h.viola at bom.gov.au
Ph. 61 39669-4403 (w)
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of James Net
Sent: Monday, 9 January 2006 1:49 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Map not rendering
Hi all,
While I hope this is not a silly question, I fear it is, or at least would
have a simple solution.
I am trying to render a map with ms.
If I do the following, the map renders and all is fine:
http://myserver/cgi-bin/mapserv?map=/var/www/html/workshop/start3.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=mymap
However, if I try the following, nothing is rendered - just a solid white
square:
http://myserver/cgi-bin/mapserv?map=/var/www/html/workshop/start3.map&mode=map
I'm just using a simple map file:
MAP
NAME TEST
IMAGETYPE jpeg
EXTENT 140 -40 150 -33
SIZE 600 600
#SHAPEPATH "/home/data/map/Landsat Mosaic TM2000/GDA94LL/"
DEBUG ON
# TEMPLATEPATTERN 'start'
WEB
TEMPLATE 'start_template.html'
IMAGEPATH '/var/www/html/tmp/'
IMAGEURL '/tmp/'
END
PROJECTION
"init=epsg:4283" #required
END
LAYER
NAME "mymap"
DATA "mymap_mosaic_murray_geov2_WGS84.tif"
TYPE RASTER
STATUS ON
END
END
Is this odd? Shouldn't both URL's work?
I've also tried shp2img and the map correctly renders.
So why doesn't this work?:
I'm using map server on redhat.
Thanks in advance.
_________________________________________________________________
Make your dream car a reality
http://a.ninemsn.com.au/b.aspx?URL=http%3A%2F%2Fcarpoint%2Eninemsn%2Ecom%2Eau&_t=12345&_r=emailtagline&_m=EXT
More information about the MapServer-users
