WCS: error on creating large Geotiff fr om ECW
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Jan 9 01:50:42 EST 2006
Hi Frank,
thanks for the answer. I tried your suggestion, but I did not even get a map
back anymore (I waited for more than 2 minutes). The ECW file used is quite
large though.
Seems like I have to wait for ERMapper's new SDK release .....
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Frank Warmerdam
Verzonden: vrijdag 6 januari 2006 17:01
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] WCS: error on creating large
Geotiff from ECW
On 1/6/06, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
> Hi list,
> I am trying to create a Geotiff file from an ECW file using Mapserver WCS
> (Mapserver 4.8beta2, GDAL CVS 04/01/06, ECW SDK 3.3RC1).
> The request is:
http://[ip]:[port]/cgi-bin/mapserv480?map=/data/OGC_UMN_services/basispakket
_dkln.map&bbox=157200,456945,161080,459273&service=WCS&version=1.0.0&excepti
ons=application/vnd.ogc.se_xml&request=GetCoverage&coverage=AAA154&crs=epsg:
28992&resx=.5&resy=.5&format=Geotiff
> The following error message occurs:
> error: could not get data:
> NCScbmReadViewLineBIL failed.: Unable to access file. GDALRasterIO()
> failed: drawGDAL()
> The same part of the ECW can be rendered by Mapserver WMS without
> problems. When I try a smaller WCS request, it does work.
> Any ideas what could be the problem and how to solve it?
Bart,
I can't think of any obvious reason this would be happening.
Especially why WCS and WMS would react differently in
this regard.
I have run into a few bugs in the last few months that relate
to unusual access patterns to the ECW SDK from GDAL. Some
of these (or all?) all been fixed by ERMapper and should appear
in their next release. But I don't know when that will be.
You might have some luck fiddling with the config settings
that can affect the GDAL ECW drivers low level access.
For instance, trying setting the following in your mapfile.
CONFIG "GDAL_FORCE_CACHING" "YES"
This will generally reduce MapServer performance since
the alternative (one big request to the ECW file is usually
faster than many smaller block reads for the cache), but
it might be more stable.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
