ogr2ogr works on Linux, does not on Windows
Xin
crazygecko at GMAIL.COM
Mon Jan 9 08:41:36 EST 2006
I thought this initially too. I'm using fwtool shell, so all the necessary
enviromental vars should be already set.
What other data files does proj use apart from epsg?
I have read the ReadMe.txt, it contain anything on setting correct data
files.
Appreciate the help.
Cheers,
Xin
On 09/01/06, Norman Vine <nhv at cape.com> wrote:
> Xin writes:
> > I am trying to convert a shapefile to tabfile whilst reprojecting it to
> LatLong WGS84.
> > This works great on Linux, but doesn't on Windows.
> > I am using the latest FWTools.
> My guess is that Proj isn't finding its 'data files'
> see the "ReadMe.txt" file in your Top Level FWTools directory
> This is normally "C:\Program Files\FWTools%VER%"
> HTH
> Norman
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060109/075b5bed/attachment.html
