Shapefiles doubts
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Tue Jan 10 15:49:58 EST 2006
many questions :-), some answers inline.
Best regards,
Bart
Apeksha Bhambhani wrote:
> Hiii all ,
> These are the few doubts that we have , could somebody please help us .
> 1.While writing the mapfile , we need to specify the extent of the map
> . The background map chosen being in PNG image type , how do we get
> the extent of this image , so as to enter this data in the mapfile .
Normally raster files have a file associated with them which contains
the georeference information. For instance a tiff file is often
associated with a tfw file. These files are also known as world files.
If you just have a PNG file, there is no way to find out the extent from
the file itself. Maybe the person who created the file knows, otherwise
try to overlay the raster file with a vector file (roads, rivers etc.
from the area) and determine common points, these are called GCP's or
ground control points. If you have enough GCP's you can georeference the
image using e.g. FWTools.
> 2.In interactive web-mapping , do we need MySql to store the data of
> the various points being plotted on the map or are the
> shapefiles sufficient .
What is your definition of interactive web-mapping? If your data is
static, shapefiles are sufficient. If you need transactions, I would
recommend using PostGIS as the datastore.
> 3. We are working on an online project and when a new point needs to
> be plotted on the map and displayed , how can this data be entered
> into the shapefiles . We have read somewhere that Mapscripting can be
> used to convert textfiles to shapefiles .
> Can you please direct us as to how can that be done ???
As I said before, I would recommend using PostGIS instead and then you
might use Geoserver on top as a transactional Web Feature Service (WFS).
I don't know if this is within the scope of your project though. There
is also a project in PHP which provides access directly to the PostGIS
functions which can be found here:
http://avoir.uwc.ac.za/projects/postgis
> 4. We have got to know about this book "Web mapping illustrated - By
> Tyler Mitchell , O'reilly Publications " . Has anyone used used it for
> developing an online interactive web-mapping apllication (example
> editing of maps ).
I am a bit biased since I was one of the technical reviewers :-). It is
a hands-on book which will teach you the basics for sure, but the main
focus is not on Mapscript. Please note Mapserver is not focussed on
editing, so the book is also not.
> Thanks in advance ...................
> Regards
> Apeksha
> Yahoo! Photos
> Got holiday prints? See all the ways
> <http://us.rd.yahoo.com/mail_us/taglines/holidayprints/*http://pa.yahoo.com/*http://us.rd.yahoo.com/mail_us/taglines/photos/evt=38089/*http://pg.photos.yahoo.com/ph//print_splash>
> to get quality prints in your hands ASAP.
OSGIS, Open Source GIS
http://www.osgis.nl
