arcSDE support for ms4w
Christopher Condit
condit at SDSC.EDU
Tue Jan 10 18:46:44 EST 2006
Hi-
MS4W doesn't support ArcSDE out of the box. If you don't want to build
MapServer from source, you can grab binaries with ArcSDE support here:
http://hobu.stat.iastate.edu/mapserver/
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of krishna S
Sent: Tuesday, January 10, 2006 3:27 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] arcSDE support for ms4w
Hello all,
I installed ms4w mapserver and its working fine. I want to make a
connection with ARCSDE so i installed ARCSDE 9.1 client APIs. When i
include the connection steps in the mapfile i get the following error
Warning: [MapServer Error]: msSDELayerOpen(): SDE support is not
available.
in C:\ms4w\Apache\htdocs\mapserverdata\test.php on line xx
Fatal error: Call to a member function on a non-object in
I am not sure about the cause of this error. Does ms4w support ARCSDE,
if
so can anyone please tell me how to compile it to make ARCSDE work. If
MS4W
does not support arcsde can you suggest some other version of mapserver
which is available (Please provide the link ....)
Thanks for all your help ....
