Problem in Oracle Spatial Connection - Empty Image
Prema Selvam (sent by Nabble.com)
lists at NABBLE.COM
Wed Jan 11 08:17:03 EST 2006
Thanks for the quick reply.
I tried your method by passing the countrymap in the query as given below and added the status of the layer as default in the map file.
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/sdocountry/sdocountry.map&layers=countrymap&mode=map
Now an error message is generated while running the above query as
msDrawMap(): Image handling error. Failed to draw layer named 'countrymap'.
msOracleSpatialLayerOpen(): OracleSpatial error. OracleSpatial is not supported
Please support me to solve the problem.
Waiting for the Reply.
Thanks & Regards,
Prema Selvam.
View this message in context: http://www.nabble.com/Problem-in-Oracle-Spatial-Connection---Empty-Image-t888093.html#a2319215
Sent from the Mapserver - User forum at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060111/5b9a1b38/attachment.html
