Projection WGS84 in decimal degree
zze-SIGALE PORTANERI F ext RD-BIZZ-SOP
fportaneri.ext at RD.FRANCETELECOM.COM
Thu Jan 12 04:52:13 EST 2006
Hi Frank & Ed,
Thanks for your prompt and efficient answers!!!
You're right, the pbm seems to come from the prime meridiam mismatch (and not decimal degree conversion issue as I thought before).
I was able to confim this by manually doing some conversion tests using the Convers useful little tool (http://vtopo.free.fr/convers.htm ).
As per example, for a WGS84 GPS point in Paris: longitude=2.38388 latitude=48.85562
In Lambert II Etendu, I have today (wrong value) : X=775063.135566471 Y=2431242.54750943
which is given using "Paris" as origin in Convers and which corresponds to the postgis transform call :
psql> select public.transform(GeometryFromText('POINT (2.38388 48.85562)', 4326), 27582);
SRID=27582;POINT(775063.135566471 2431242.54750943)
So I have to find other EPSG values to get the correct X/Y that should be:
X=603478.33780249 Y=2428587.76696934.
I didn't find it yet, but I keep investigating in the spatial_ref_sys postgis (0.9.1) table!!!
Regards,
FP
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Ed McNierney
Envoyé : mercredi 11 janvier 2006 16:47
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] Projection WGS84 in decimal degree
Frank & FP -
Good catch, Frank - that's an excellent possibility.
FP, make sure your EPSG file contains an accurate definition of <27582>, including the prime meridian (primem) of 2.337229166666667.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam
Sent: Wednesday, January 11, 2006 10:16 AM
To: Ed McNierney
Cc: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] Projection WGS84 in decimal degree
On 1/11/06, Ed McNierney <ed at topozone.com> wrote:
> FP -
> Your first GPS layer definition should be fine. You don't say what
> data source you are using for your GPS data, but if it is a shapefile
> or inline features you will be using decimal degrees and those will
> work fine with the "init=epsg:4326" definition.
> The first thing I would suggest is that you confirm that the
> EPSG:27582 projection is in fact correct. The related Paris / Lambert
> projections (27581-27584, for example) are all rather similar and can
> certainly look the same. Can you check the coordinates of a few
> points to make sure they're accurate? An error of 200km is far too
> large to be a datum error, but could easily be due to the different
> false easting/northing values used in these similar projections.
FP,
I would add to Ed's comments that the PROJ definitions files for EPSG zones with alternate prime meridians are often messed up, and a horizontal offset of 250km is approximately the distance of the paris meridian from greenwich.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
