GDAL support the reading of ERS and ASAR data in tiff format?
Gail Millin
Gail.Millin at MANCHESTER.AC.UK
Fri Jan 13 08:35:10 EST 2006
Hi Frank,
I have added the PROCESSING "SCALE=AUTO" in the mapfile however still no luck. Taken a look at the raster howto and the data I am trying to serve is unsigned 8bit data. I am confused on how I classify unsigned 8bit data and is it MapServer that would generate a look up table?
Thanks for your help
Gail
> Gail,
> I am not familiar with distribution of ASAR data in GeoTIFF
> format, but I would guess it is 16bit data and so you will
> need to apply some scaling to it for visualization purposes.
> You could start adding the line:
> PROCESSING "SCALING=AUTO"
> But you may later want to specifically control the scaling.
> Read up on scaling in the raster howto.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
