PostGIS problem
Krung Saengpole
saengpole at YAHOO.COM
Sat Jan 14 00:42:45 EST 2006
Thank you for your help. Actually, I had a problem calculating area of forest inside any circle area and draw map with mapserver with this circle. But I didn't know how to start with postgis instead of postgis and postgresql documents.
Thank you again.
Krung
David Bitner <osgis.lists at GMAIL.COM> wrote:
If you are going to be doing much work with PostGIS, this question is
better suited to the PostGIS users list that can be found along with
documentation for PostGIS at http://postgis.refractions.net
To create a circle with an x,y, and radius all you will need to do is
a buffer of an x,y coordinate. For example: buffer(makepoint(x,y),r)
On 1/13/06, Krung Saengpole wrote:
> Hi all,
> I'm a newbie with postgis and postgresql. I'd like to convert circle
> '((x,y),r)' in postgresql to geometry for using with postgis functions. How
> can I do it? Please give me an example or some function scripts to start
> with.
> Thank you.
> Krung
> ________________________________
> Yahoo! Photos Showcase holiday pictures in hardcover
> Photo Books. You design it and we'll bind it!
Yahoo! Photos
Got holiday prints? See all the ways to get quality prints in your hands ASAP.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060113/9ae918a6/attachment.html
