Bug in msSaveSymbolSet
Sean Gillies
sgillies at FRII.COM
Mon Jan 16 15:11:54 EST 2006
On Jan 16, 2006, at 8:42 AM, Albert Rovira wrote:
> Hi all,
> I found a litte bug in function msSaveSymbolSet. It don't close the
> file
> stream, so data about symbols are lost.
> int msSaveSymbolSet(symbolSetObj *symbolset, const char *filename) {
> FILE *stream;
> int retval;
> if (!filename || strlen(filename) == 0) {
> msSetError(MS_SYMERR, "Invalid filename.", "msSaveSymbolSet
> return MS_FAILURE;
> stream = fopen(filename, "w");
> retval = msSaveSymbolSetStream(symbolset, stream);
> return retval;
Good catch, Albert. It's fixed for 4.8 and 4.9.
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
