Merging Regions of a shapefile
Adam Quiney
aquiney at REFRACTIONS.NET
Mon Jan 16 17:43:51 EST 2006
Neil,
You could also accomplish this using FME, with a
PolygonDissolveFactory. FME *is* a proprietary application, with a
reasonably hefty pricetag. However, you can download a 15 day trial
version from SAFE (http://www.safe.com) and give it a shot. This will
merge together your geometries very quickly, but if this is the only
processing you need to do on your data, and FME license would likely be
overkill.
--Adam
Brock Anderson wrote:
> Neil,
> I can't say much about OpenEV, but you may be able to use one of the
> geometry constructors to group your region polygons together. Perhaps
> the "collect" function would do it?
> Docs here: http://postgis.refractions.net/docs/ch06.html#id2905042
> Brock
> Neil Saunders wrote:
>> Hi Brock,
>> Thanks for your reply; However I've tried using PostGIS but could't
>> get the shapes to actually "merge" together. Ideally what I'd like to
>> do is have a tool such as OpenEV in to which I could load my
>> shapefile, select a given number of *adjacent* regions, and merge
>> selected regions to a single region, if you catch my drift. I'm
>> beginning to think that it may not be possible... :(
>> Thanks once again for you input!
>> Cheers,
>> Neil
>> On 1/16/06, Brock Anderson <banders at refractions.net> wrote:
>>> Neil,
>>> I tend to use Postgres/PostGIS for this kind of processing.
>>> For example:
>>> Load the data into postgres like this:
>>> shp2pgsql <loader options here> england.shp england_table | psql
>>> Then dump it out again into several shapefiles. Use an SQL statement to
>>> select the regions to include in each file:
>>> pgsql2shp <dumper options here> england_table "select * where ..."
>>> Brock
>>>> Hi Folks,
>>>> I've got a map of England as a shapefile, containing regions for each
>>>> county. What I'd like to do is merge selected regions in to a larger
>>>> region (E.g Devon, Somerset, Cornwall etc into "Westcountry").
>>>> Does any one know a simple (Preferably GUI based) way of achieving
>>>> this?
>>>> Thanks in advance,
>>>> Neil.
Adam Quiney
Analyst
Refractions Research Inc.
(250) 383-3022
