No reprojection done
Ed McNierney
ed at TOPOZONE.COM
Tue Jan 17 10:46:18 EST 2006
Luiz & Bengt -
I would expect that if Bengt is working with maps of Scandinavian
countries, the difference between Plat Carree and Mercator should be
noticeable (Mercator will "stretch" things north/south by quite a bit
compared to a "geographic" or Plat Carree projection).
Bengt, are you sure you have a good PROJ installation and that MapServer
is compiled with PROJ support (run mapserv -v and look for
"SUPPORTS=PROJ")?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Luiz Vaz
Sent: Tuesday, January 17, 2006 12:46 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] No reprojection done
Well,
it seems that there no perceptual changes each other:
# World Mercator
<54004> +proj=merc +lat_ts=0 +lon_0=0 +k=1.000000 +x_0=0 +y_0=0
+ellps=WGS84 +datum=WGS84 +units=m no_defs <>
# World Plate Carree
<54001> +ellps=WGS84 +datum=WGS84 +units=m no_defs <>
# World Equidistant Cylindrical
<54002> +ellps=WGS84 +datum=WGS84 +units=m no_defs <>
# WGS 84
<4326> +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs no_defs <>
Best Regards,
Luiz Vaz
2006/1/15, Nilsson Bengt <bengt.nilsson at aerotechtelub.se>:
I've set up a WMS server with an initial singe layer to test
reprojection. However , I can't get the projection to work. Whatever
output projection i try I get the same geographical (4326) back. For
example, when I make a WMS request with SRS=EPSG:54004 (Mercator) and
bounding box in that projection I get an 4326-map back. I do not get any
errors. Here is my map-file:
MAP
NAME WMS-test
STATUS ON
SHAPEPATH "shp"
IMAGECOLOR 255 255 255
FONTSET ../etc/fontset.txt
DEBUG ON
WEB
LOG "/tmp/mapserv.log"
IMAGEPATH "/srv/www/htdocs/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "Test"
"wms_onlineresource"
"http://hhhhhhhhh/mapserv/wt?service=WMS "
"wms_srs" "epsg:9823 epsg:4326 epsg:54004"
END
END
PROJECTION
"init=epsg:54004"
END
LAYER
NAME k92_strandlinje
DEBUG ON
METADATA
"wms_title" "k92_strandlinje"
"wms_srs" "EPSG:4326"
END
TYPE POLYGON
STATUS ON
CONNECTIONTYPE postgis
CONNECTION "user=postgres password=xxx dbname=xxx
host=localhost"
DATA 'the_geom from k92_strandlin_polygon'
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "strandlin-pgx"
COLOR 255 251 237
OUTLINECOLOR 100 100 100
END
END
END
/Regards Bengt
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060117/7645a8f4/attachment.html
