Postgis error with mapserver
Don Isgitt
djisgitt at SOUNDENERGY.COM
Tue Jan 17 10:55:51 EST 2006
joanvp wrote:
> *Hi!!
> I've tried to show a postgis layer with UMN Mapserver. I've installed
> last version of postgresql with postgis (8.1). I've imported a
> shapefile with FME.
> I've tried this layer with Quantum GIS and all works fine. The problem
> is with UMN Mapserver (v4.6). This is the error log
> Warning*: [MapServer Error]: prepare_database(): Error executing
> POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY
> CURSOR FOR SELECT
> asbinary(force_collection(force_2d(geom)),'NDR'),OID::text from
> public.Inun_RiscAlt WHERE geom && setSRID('BOX3D(326607
> 4245586.875,627250 4471069.125)'::BOX3D,
> find_srid('','public.Inun_RiscAlt','geom') )'
> Postgresql reports the error as 'ERROR: relation "inun_riscalt" does
> not exist '
> More Help:
> Error with POSTGIS data variable. You specified '<check your .map file>'.
> Standard ways of specifiying are :
> (1) 'geometry_column from geometry_table'
> (2) 'geometry_column from (<sub query>) as foo using unique <column
> name> using SRID=<srid#>'
> Make sure you put in the 'using unique <column name>' and 'using
> SRID=#' clauses in.
> For more help, please see
> http://postgis.refractions.net/documentation.php
> This is my mapfile
> LAYER
> NAME inun_riscalt
> TYPE POLYGON
> STATUS On
> CONNECTION "user=xxx password=xxxx dbname=bdmapserver host=localhost
> port=5432"
> CONNECTIONTYPE postgis
> DATA "geom from Inun_RiscAlt"
> CLASS
> NAME "Inun_RiscAlt "
> COLOR 182 131 78
> OUTLINECOLOR 4 24 93
> END
> END
> Any solution?
> Thank you in advanced
> Yahoo! Photos
> Got holiday prints? See all the ways
> <http://us.rd.yahoo.com/mail_us/taglines/holidayprints/*http://pa.yahoo.com/*http://us.rd.yahoo.com/mail_us/taglines/photos/evt=38089/*http://pg.photos.yahoo.com/ph//print_splash>
> to get quality prints in your hands ASAP.
Joanvp,
Notice the public.Inun_RiscAlt versus inun_riscalt. Postgres forces
names to lowercase unless they are enclosed in quotes.
Don
